E34 (1989 - 1995)
Old 09-12-2005, 03:41 PM
dcpreston1 dcpreston1 is offline
Mein Auto: '99 528ITA
rear windows won't work
95 525it
When i try to roll the back windows down i just hear a little click in the motor in the door. It makes the same noise if I try from the front switches or the switch on the door. Its kind of like the sound a bad solenoid makes on a starter.
I took the door panel off and everything is connected. Is there a way to test for low voltage or any other ideas.
They worked when I test drove the car for purchase (about a month ago) and worked a few times since I bought it.
The front windows work just fine.
Thanks,
Dave in Frisco
Old 09-25-2005, 04:27 PM
FDMeloan's Avatar
FDMeloan FDMeloan is offline
Retired and happy
Mein Auto: 325Cic, Subaru OB 3.6R
Smile You probably won't believe this
Dave in Frisco:
The rear window motors on the E34 have a bad habit of "sticking".
Here's what you need to do to solve the problem.
Get in your touring and turn on the engine. Go to the back seat and hold the window switch in the "down" positon. While you are doing this hit the door panel in the middle with your fist as hard as you can.
This should "un-stick" the window motor. I know that it works in my 1995 E34 touring.
Please let us know if it works for you.
Old 09-28-2005, 03:20 AM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
I have a 1992 525 wagon and I was getting a clicking noise out of my window motor too. For months I just helped the window up and lived with it. Then the other day I took the entire door apart and with closer examination I found that the window motor needed to be replaced. It would appear that the worm drive mates with a plastic ring gear inside the 3" round plastic housing, and the clicking noise is the ring gear jumping the metal ring gear due to wear. Unfortunately, there does not seem to be a way to rebuild the unit yourself and taking it apart did not accomplish anything. Therefore, I ordered a new one from Patrick at BMA for $95. Most internet places were quoting $120 and the Stealer wanted $160 for the same part from Vemo. Note: The LF & RR motors are the same... Just as the RF and LR motors are the same.... but double check your part numbers before ordering.
Old 09-29-2005, 09:27 PM
both of my rear windows were not going down
slammed them both shut nice and hard
they both work now
if i don't use them they for a few days they stop working again
i just slam the door again and they work
goofy.
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Anyone have pics of tint 35% rear, 50% front windows? Jim H 3 Series / 4 Series 28 12-24-2004 06:19 AM
To tint or not to tint ...? buckeyebimmer 3 Series / 4 Series 28 04-07-2004 04:56 PM
Windows XP Home or Professional? piku Off-Topic 12 09-04-2003 06:59 PM
Shark Injector for E46M3 is ready... TMS92 M Series 14 06-14-2003 02:30 PM
