E36 (1991 - 1999)
Old 09-21-2005, 08:05 AM
Brian_autoX Brian_autoX is offline
Bimmer & Honda SCCA Dood
Send a message via AIM to Brian_autoX Send a message via MSN to Brian_autoX Send a message via Yahoo to Brian_autoX
Mein Auto: CRXs
Question Help?? Front end "creaking" 328is
Alright here's the down-low
Been doing my own car work for years, first time owning a bimmer as of August this year.
Since buying the 98 328is, with roughly 90k on it.. I've replaced Front Control arms (meyle replacements w/ beefier ball joints), Control arm bushings (urathane w/ offset, courtesy of bavauto), Tie Rods, Struts, and Upper Strut mounts, (still stock springs)
Here are my issue(s) possibly related?? #1. I can't figure out how to TORQUE the strut mount onto the strut, it is recessed inside, and the strut I bought has an external hex, so somehow I'd have to get that held while torquing the other, but I can't since it is all about 1.5-2" below the top of that strut mount.
Now during slow turns, I can hear/feel what i can only describe as a "creak" in the driver's side, I am not sure if I perhaps have the strut too tight? or not tight enough?? previously I could hear it rattle/clang when I first assembled it and test drove it, I knew it wasn't on tight enough, so I tightened it more (Air Impact is the only way I could seem to get to it). now (and before) it creaks at low speeds, basicly seems to creak anytime the shock tries to rotate (which it does during turning I believe). At first I thought it was just the springs trying to settle in, but now almost 500-1000 miles after that adventure it continues to. I had one suggestion of possibly the delrin inserts in the Control arm bushings causing the creak as the arm tried to rotate inside, but I greased those and continue to have this 'creak'. The bearings in the strut mounts are packed w/ grease, and it is JUST the driver's side, not both, so I'm confused, and looking for suggestings... Please?
Thank you in advance for any help!!!
Old 09-23-2005, 11:48 AM
Mein Auto: CRXs
No other ideas? or any one know for sure? thank you!
Old 09-29-2005, 03:37 AM
G_VMP G_VMP is offline
Mein Auto: Bmw 320i
sounds like it cud be your drive shalfs that are away. ive had a problem before with driveshafts. its very easy to fix.
Old 09-30-2005, 09:21 AM
Mein Auto: CRXs
Thumbs down
LOL, I'm not sure about yours, but my BMW is rear wheel drive.
And the sound is in the front Suspension.
Similar Threads
Help - Trying to figure out front end shimmy STEVE46 E46 (1999 - 2006) 2 08-22-2005 03:56 PM
E 38 Front end shake bmw cyclist 7 Series & 8 Series 1 08-15-2005 07:51 AM
Anyone else scrape their front end yet? jtmililani808 E90/E91/E92/E93 (2006 - 2013) 18 07-15-2005 02:56 PM
Front End Clunk Sound c362137 3 Series & 4 Series 4 10-22-2004 01:16 PM
Epel plastic front end paint protector. Stevarino Ask-A-BMW-Dealer 8 11-04-2002 07:23 PM
