E36 (1991 - 1999)
Old 09-22-2005, 11:03 PM
rpburg rpburg is offline
Mein Auto: 02 330Ci Vert
Unhappy Acceleration misfire
Need help determining cause of misfire when accelerating at about 2000 rpm. The car is 98 323i manual transmission. Replaced plugs and still misfiring. Plugs removed were clean. Typically notice misfire/ lugging in 1st and 2nd gear. Raging in 3rd and 4th gear (high rpms) and car runs great. Anyone have a similar problem and fix it? I've read about everything from idle control valve to fuel pump to coils but no sure cure.
Old 09-23-2005, 06:32 PM
Went to independent today. Found an O2 sensor code (but check engine light not on). Sensor seemed to be functioning fine during idle. Plan is to see if I can get the code to reset again after driving car for the weekend and confirm the O2 fault. He also suggested it might be the air mass meter starting to go bad. The best thing... no charge unless he actually fixes something.
Anyone have an opinion?
Old 09-23-2005, 09:06 PM
screwuphead screwuphead is offline
Mein Auto: BMW 325i E36
i have the same problem and i am going ot change my fuel injectors ill tell you if that works!
Old 09-29-2005, 02:34 AM
G_VMP G_VMP is offline
Mein Auto: Bmw 320i
The fuel injectors are definatly blocked by wat ive heard, ive knowen ppl with simular problems
Old 09-30-2005, 12:22 AM
frost_dxb's Avatar
frost_dxb frost_dxb is offline
Mein Auto: C200K, 318i, 325e
why change when you can always get that injectors serviced at less $$$?
2002 C200 KOMPRESSOR
1995 318i - M42B21 on going Project
1992 325i AC Schnitzer - SOLD in DXB
1990 525i - SOLD in DXB
1989 E300 - SOLD in DXB
1989 M6 - SOLD in DXB
Similar Threads
Intermittant Misfire on Idle - Hot and Cold Rickster100 E36 (1991 - 1999) 7 10-04-2009 01:23 PM
misfire asf4life E46 (1999 - 2006) 7 01-08-2009 03:28 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Airbags and full face helmets ·clyde· Motorsports, Racing & Track 43 11-20-2004 11:44 AM
0-60mph acceleration time grumpsy 3 Series / 4 Series 23 06-11-2002 07:46 PM
