E34 (1989 - 1995)
Old 09-24-2005, 05:49 PM
RIPDOTCOM RIPDOTCOM is offline
Mein Auto: 1993 525i
LCD Panel went nuts
i was driving today and the LCD panel went haywire then shut off. The car runs fine and after parking for a bit i fired it back up and the LCD was fine. WTF?
Old 09-28-2005, 04:24 AM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
If you have a pre-1995 with a gear selector switch... it's probably time to clean it. Do a seach on this.... The part is located under your center console cover. It tells the LCD what to display and serves as a neutral postion switch so you can't start you car in drive. BTW, you might notice an improvement in acceleration and better MPG if you clean the switch since it alls talks to the DME.
Similar Threads
LeatherZ E46 Gauge Panel Install w/photos Scott ZHP E46 (1999 - 2006) 40 07-06-2010 03:48 PM
1996 318is drive panel lights don't work Das Chimney E36 (1991 - 1999) 2 03-27-2008 05:04 PM
Need a Cheap LCD Monitor? xspeedy Off-Topic 2 04-21-2005 01:30 PM
Nuts Ron Stygar E36/7 Z3 (1996-2002) 6 11-01-2004 08:35 AM
Check your nuts Stuka General BMW Questions 12 11-10-2003 04:24 PM
