For Sale : Andy Basham's STX BMW 330i ZHP
This car finished in 2nd place at the 2005 Solo 2 Nationals… setting the quickest time in STX on day 2 in the dry!! This very well could be your new STX overdog!!
I honestly hate to part with the car, it's been my baby for the last 2 1/2 years. It's been well maintained inside and out. I'm the original owner. I have all the original documentation including when fluids were changed. I'm selling the car because I want to try a different car and/or class next year.
The car came with a strong engine from the factory, putting down 10 HP more to the wheels then any other stock 330i ZHP that I've seen dyno'd (see dyno graph below).
No expense was spared!! I have nearly $65,000 into this car ($45k purchase price + $20k STX mods). I figure you could build one today for about $52,000 ($32k market value + $20k STX mods). Make me an offer (serious offers only, please). If you already own an E46 BMW, I'd consider selling all the STX mods as one package. My email address is [ andybasham at hotmail dot com ]. I'd be happy to answer any questions you might have and willing to work with you on a fair price for the car.
Factory Specifications:
2003 BMW 330i ZHP (VIN : WBAEV53443KM04167)
- Black Sapphire Metallic
- Black Leather Interior with Aluminum Cube Trim
- Performance Package (ZHP)
- Cold Weather Package
- Power Moonroof
- Xenon Headlights
- OEM BMW Alarm
- OEM BMW Universal Receiver (built in garage door opener)
The car has 41,000 miles on it. The car went through proper break-in procedure for the first 1,250 miles. All fluids changed after break-in. The engine oil has been meticulously changed every 5,000 miles (or less) with full synthetic oil. The transmission and differential fluids changed every 20,000 miles with RedLine fluids. The new limited slip differential went through proper break-in procedure for the first 1,000 miles. The diff. fluid was changed after 100 miles and then again after 900 miles. Full documentation showing date, mileage and brand of oils used for all fluid changes since the life of the car. Engine oil, transmission fluid and differential fluid was last changed on 9/4/2005 with RedLine fluids. Brake fluid was just flushed and replaced with ATE Super Blue the same day.
The car was used as a daily driver for the last half of 2003. The car was autox'd regionally and divisionally in B Stock in 2004. The car was autox'd regionally, divisionally and nationally in STX in 2005.
Here is a list of mods along with their purchase price so you can see a break down of what went into the car. All of these parts were purchased brand new and installed in 2005 (Koni shocks and front sway bar were purchased new and installed in 2004).
Suspension :
$2106.34____TC Kline Racing Smart Design D/A Coilover System (D/A Konis, 500# Springs, etc.)
$550.00_____TC Kline Racing Camber/Caster Plates
$105.00_____TC Kline Racing Rear Rubber Upper Shock Mounts
$389.00_____Racing Dynamics Front and Rear Sway Bars
$389.20_____Extra set of TC Kline Springs Front and Rear (450# springs all the way around)
$150.00_____Custom Fabricated Delrin Front Control Arm Bushings
$150.00_____Custom Fabricated Delrin Rear Trailing Arm Bushings
$369.00_____UUC StrutBarbarian Strut Brace (Magnesium w/ Aluminum ends)
_______
$4208.54
Engine & Drivetrain :
$349.00_____Eurosport EvoII Carbon Fiber Conforti Intake
$1095.00____UUC TSE3 Cat-Back Exhaust
$160.00_____UUC Underdrive Pulleys
$800.00_____Custom ZHP ECU Tuning by Oscar Velez (www.oscarvelez.com)
$4100.00____Custom Built E46 Limited Slip by Jim Blanton (www.PerformanceGearing.com)
_______
$6504.00
Seats :
$1198.00____Recaro Pole Position Seats (black cloth / driver and passenger)
$340.00_____Aluminum Adapters for Pole Position Seat
$130.00_____Flat Sliders for Recaro Seats
$379.90_____VAC Motorsports Aluminum Floor Mounts
$449.98_____Schroth Rallye 4 Quick Fit Harnesses (red / driver and passenger)
_______
$2497.88
Wheels & Tires :
$1600.00____(4) 17x8 SSR Competition Wheels (silver)
$756.00_____(4) 235/40/17 Yokohama ADVAN Neova AD07s shaved to 4/32nds
_______
$2356.00
Brakes :
$446.00_____Brembo Cross-Drilled Factory Replacement Rotors
$127.00_____Goodridge Stainless Steel Brake Lines
$136.57_____HAWK HPS Brake Pads
_______
$709.57
Misc. Items :
$85.95______Lightweight Battery - Enersys ODYSSEY PC680
$69.95______BimmerHaus Russ Wiles Battery Box
$277.00_____Da Lan Trailer Hitch (this is easy to unbolt and remove)
$550.00_____Cosmetic : Clear Lens Kit (front corners, taillights & side markers)
$75.00______Cosmetic : M3 Pedal Kit (including dead pedal)
$150.00_____Cosmetic : 38% Llumar Window Tint
_______
$1207.90
$17,483.89___PARTS
$2,500.00____ESTIMATED SHIPPING COSTS ON PARTS
$0.00________LABOR (all done by yours truly )
_________
$19,983.00___TOTAL COST OF STX MODS
Dyno Results :
Stock Trim
Weight :_______3,300 lbs (estimated)
Horsepower :___207
Torque :_______200
STX Trim
Weight : _______3,096 lbs *
Horsepower : ___214 (10 hp gain at 2300 RPM)
Torque : _______209 (24 ft lb gain at 2300 RPM)
* I weighed the car at the Peru National Tour and had the car down to 3,150 lbs. Before Nationals I removed the last two sections of the exhaust and ran a turn-down pipe (which will come included), which shaved 41 lbs. I also removed the tow hitch, which shaved another 13 lbs.
Red Line :______ECU Tuning, Intake, Exhaust, Pulleys and Lightweight Wheels
Green Line :____Intake, Exhaust, Pulleys and Lightweight Wheels
Blue Line :______Stock
My dyno results :
Here's a link showing a dyno run from someone else's stock 2003 330i ZHP putting down 197 HP and 200 ft lbs of torque. Showing my car came with a strong engine from the factory.
http://www.bimmerfest.com/forums/showpost.php?p=685404&postcount=1
All original OEM equipment will come with the car :
- Front driver and passenger sport seats (black leather)
- Air box and filter
- Pulleys and original belt
- Exhaust
- Shocks, springs, strut hats and spring perches
- Sway bars
- Differential
- OEM 135M 18" Wheels with 255/35/18 Michelin Pilot Sport PS2 tires (50% tread left)
- Amber colored front turn signals, taillights and side markers
- Spare tire, jack and tools
- Original 12 Volt Battery
Pictures :
- Power Moonroof
- Xenon Headlights
- OEM BMW Alarm
Suspension :
_______
$4208.54
_______
$6504.00
Seats :
_______
$2497.88
Wheels & Tires :
_______
$2356.00
Brakes :
_______
$709.57
Misc. Items :
_______
$1207.90
$17,483.89___PARTS
_________
Dyno Results :
Stock Trim
Horsepower :___207
Torque :_______200
STX Trim
My dyno results :
- Exhaust
- Sway bars
- Differential
Pictures :
