E36 (1991 - 1999)
Old 09-27-2005, 08:07 PM
golfmurph golfmurph is offline
Mein Auto: 1992 BMW 325 E36
Question 1992 325 e36- Noise on Right turns? Help?
Whenever I make a right turn at slower speeds say 15-35mph, I hear a rattle that sounds like it is coming from under the armrest between the front seats. I thought at first it may have been teh rear shocks/shock mounts, but replaced those. Someone mentioned it might be the differential? I am going to start by replacing the differential fluid to see if we see anything, Any ideas on what else may be causing the noise, any help is appreciated. Puzzled.
Old 09-29-2005, 02:29 AM
G_VMP G_VMP is offline
Mein Auto: Bmw 320i
It cud well be your wheel bearings, drive shalf or cv joints. which arnt all that pricy to fix
Old 09-29-2005, 05:01 AM
wavewuver wavewuver is offline
Mein Auto: 2011 X3
Check to see if your parking brakes cables are loose. Pull up the cover at the base of the parking brake lever. There shouldn't be any slack. I had this rattle once and that's what it turned out to be.
Old 09-29-2005, 06:06 AM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
That sounds like it could be the beginning of a guibo disk going bad.
I say that because the sound is coming from the arm rest area. The part is about $50-$60 and can often be found on eBay.
If you are good with tools and can get your car in the air safely you can do the job yourself.
Photobucket
Old 09-29-2005, 07:56 AM
BeRzErKaS's Avatar
BeRzErKaS BeRzErKaS is offline
U know how the game goes
Mein Auto: BM-double Who's?
This may seem like splitting hairs but as best you can describe is it a steady low-pitched KNOCKING/ "THUNKING" sound or is it truely a RATTLE (randomly timed tap/clanking sound)? Does it get worse the more you turn the wheel?
Do you feel any reverberation in the steering wheel when you hear this sound?
Also, is your car manual or automatic?
BMW 3 Series - "Consistency of Purpose...Excellence of Execution."
Supercharged E36 325is 5sp
::ERT S/C, Auto-Manual Conv, SPAL Fan, Zeitronix, SAFCII, Alpine, Autotek, Orion, Angel Eyes, Tinted, Smoked, Trackpiped, and so much more::
Drop Top E46 330cic Step
::PP, SPP, CWP, HK, BT, Lumbar, Xenon, Tints, Clears, Remus Exhaust, ///M-Tech Wheels::
Old 10-03-2005, 05:09 PM
Info
Thanks for all the info. The car has a manual transmission. LAter this week I plan to check out some of the things mentioned. The noise sounds like two pieces of metal that are clunking /rattle when making the turn, very predictable when it happens and consistent noise. My thought was differential slipping, any ideas what that may sound like?
Old 10-05-2005, 04:10 AM
Dudesky_E36's Avatar
Dudesky_E36 Dudesky_E36 is offline
Run Far
Mein Auto: 2001 Anthracite 530iA
Try wiggling your exhaust somewhat forcefully from side to side. It could be the exhaust hanger tabs in that area scraping against the pipes when you turn. I had this peoblem a few months ago, and it sounded like that. It was hard to diagnose because the exhaust looked and felt like they were solid enough. Apparently not so. One day I banged my knee against the exhaust tips, and voila- there was the sound
Similar Threads
BMW Noise Troubleshooting Alex Baumann General BMW 3 08-14-2008 02:40 PM
2005 325 Rear window noise atlengineer E46 (1999 - 2006) 0 08-30-2005 03:05 PM
Wanted Cat Converter for E36 325 1992-95 Canada/US Mastronardi Classifieds 2 01-16-2003 10:55 AM
E34 or E36 Michael330 General BMW 44 08-25-2002 05:59 AM
Road Noise in E36 M3? Jetfire 3 Series / 4 Series 36 07-27-2002 10:47 AM
