E36 (1991 - 1999)
Old 09-30-2005, 08:57 PM
Bogwon Bogwon is offline
Mein Auto: 1995 M3
Headlight switch dash light
How tough is it to replace the dash light that illuminates the headlight switch on a '95 E36? I've had the car for a few months, the headlight switch has never been illuminated, but I'm sure it should be. Thanks for any help.
Old 10-01-2005, 03:56 AM
my_e36 my_e36 is offline
Mein Auto: e36 323i coupe
Remove lower driver dash (the one under the steering wheel, 4 screws total, 2 of them are on the underside), remove the know by pulling straight out (might want to use some double sided tape for leverage), then there's a hex-shape nut holding the switch onto the dash, remove that and the whole unit drop out from bottom. Then you can replace the bulb.
Installation is reverse of removal.
Similar Threads
Need rear fog light help. JonM E36/7 Z3 (1996-2002) 13 04-09-2013 03:28 PM
dash lite/R LIC PLATE lite stay on after switch is off 94black325i E36 (1991 - 1999) 11 08-12-2011 07:16 PM
How many fest members does it take to change a light bulb? .... Sabrina Off-Topic 14 03-03-2003 05:49 AM
dash light appears ashecnc General BMW Questions 30 01-06-2002 03:53 PM
