Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 01-15-2009, 10:40 PM
Burnsie828 Burnsie828 is offline
Mein Auto: 2000 323i
Originally Posted by almoula View Post
New Problem: next day the tank was full and no leaks whatsoever. But when every I told my girlfriend to press the lever to get the pump going I hear the pump working but no water is coming out. So after chewing on the problem for little while I remembered (being an engineer and all) that air must have gotten into the pump and cavitation is occurring. What happens is water is sucked in but cannot leave or it leaves very slowly due to the existing of air bubbles that the pump is spinning instead of water so need to clear this problem.
Solution: while the pump is attached to a full tank and all electrical wiring is attached unhook the hose from the pump line (you know the hose that connects the cars windshield washer to the pump) insert a hose of similar dimension and have it pointing away from the engine tell a friend or preferably a girlfriend to pull the lever to get the pump going. At first pressure will be little and little water will come out but after a second the waster bubbles will come out along with a strong jet of water, now you have no water bubble that can cause cavation. Carefully unplug the hose from the pump. Place your hands on the pump hole then put the cars windshield washer line quickly into the pump. And you are done. Everything should work.
Now you might ask now wait why not just connect the cars line in the first place and just press the lever to get the pump going, you would think that I the pump will take water from the tank and expel the bubbles through the washer jets, but actually the pressure restriction inside the hose of the car is much greater than the pump can overcome ( this only true when water bubbles are present ) so that's why you had to do the separate hose to allow for true atmospheric pressure to help the pump expel the bubbles and operate at pristine order.
First time poster here, so forgive me if I do any of this wrong. I seem to have the same problem as described here. My washer fluid tank is full (and has been for the three years Ive owned the car -- 2000 323i) and the fuses are all good. Yes, I finally decided to figure out how to fix this midly annoying problem after three years! Anyway, when i pull the lever, i hear the hum of what I assume is the pump, but nothing comes out. Rather than trying to fix a potential cavitation problem, will simply replacing the pump solve the problem?
Or, can I solve the cavitation problem by simply removing the hose and pulling the lever until the air bubbles come out of the pump directly? In other words, if i dont have a similar hose to attach, can the cavitation be fixed without one?
Great thread by the way.
Old 01-19-2009, 10:52 AM
2000323iguy 2000323iguy is offline
Wiper Pump
Just wanted to say thanks for posting the DIY. Saved me mucho bucks! Just signed up for the site because it has been helpful so many times and wanted to be apart.
Old 01-19-2009, 03:50 PM
MontereyDave MontereyDave is offline
Mein Auto: E90 328i
Originally Posted by WAM View Post
Procedure to change the windshield washer tank or pump on an E46.
Tools needed: 10mm spanner (in toolkit), small-medium flat blade screwdriver
Undo the 10mm nut, highlighted in the red circle. This is the only fastener holding down the washer tank. Lift the tank up about 4", allowing you to unclip the black plastic heatshield around the washer pump. This is where you need the screwdriver, to lift the securing tab from the washer tank (yellow circle). You can actually pull out the complete washer pump from the tank. Just gently pull up, it is a friction fit.
Now unclip the washer level sensor plug (green circle). This clip is a little difficult to figure out. I pulled it hard and it came off. Taking a closer look at it once it was off, I couldn't quite see how to unclip it from its securing catch.
At this point you have removed the washer tank. The two tabs at the bottom of the tank fit into recesses in the body work, in order to secure the tank. There is a filter screen in the tank, where the washer pump plugs into the tank (blue circle). Just pry this up with a screwdriver to remove it. I had bought a new one, just in case. You can see the fluid level sensor socket on the left side of the tank in this pic.
Now unclip the pump connector from the pump. Pinch the tab at the top of the connector. This will unclip the connector from the securing tab. Pull out the water hose from the nozzle on the pump
Replace the pump filter screen into the tank, if necessary. Plug in the new washer pump into the filter screen. Connect the water hose back onto the pump.
Position the washer tank into its approximate location and clip the sensor for the fluid level back into its socket on the tank.
Secure the heatshield back onto the tank.
Now position the washer tank into its secured position and fill with a little water, in order to test the pump out. Fasten the 10mm screw back into the plug.
Originally Posted by 323i-drive View Post
Thanks for the DIY! Got it for $13 at the local Auto Zone in Denver and didn't get through a Coors Original before it was working. If you get the TAAP Corp part from Auto Zone the blue/yellow stripe wire from the new motor connects to the black ground wire of the e46 harness. That level sensor does seem to have a small compression tab pointing up that I hit with a plier and it came right off. Also, if you don't feel like washing the garage floor try to siphon the washer reservoir first. When pulling that motor pull up and push towards the engine and it will come out faster. I lost a liter or more of "blood" before I get the offending organ out.
Hey guys, just a note to say thank you and to introduce myself.
I recently bought a black/black '03 325i that I love in and out except the windshield wiper washer pump was inop. With your help it ony took me 5 minutes to replace it with a great working Autozone washer pump.
Old 01-26-2009, 06:12 AM
zoltar9 zoltar9 is offline
Mein Auto: London
Great, saved me a trip to the local garage!
And saved me money as well. All I had to do was clean the tank, which was full of limescale and blocking the filter. Now it works like new. Thank you!!!
Old 02-19-2009, 04:04 PM
mickey513 mickey513 is offline
Send a message via AIM to mickey513
Mein Auto: e46
Is the grommet included in the dealer part or siemens washer pump? All the place I gone to online shows the grommet can be purchased seperately ...
Old 02-21-2009, 03:03 PM
illprophecy238 illprophecy238 is offline
Mein Auto: BMW 323i
thank you sooo much
this site is wonderful!
thank you so much for this post..you guys saved me hundreds of dollars!
bless you guys!
Old 02-25-2009, 01:06 PM
kingwu_98 kingwu_98 is offline
Mein Auto: E46
I bought the pump form ebay. took about 8 day from US to NZ
Put in the pump, did not work at first, and I recall in the replies you need to take out the air pockets
once air pockets removed... pump working as new... saved 50% (including the postage paid) of the retail price in NZ
Old 02-26-2009, 12:33 PM
jpg2003 jpg2003 is offline
Mein Auto: 535
Great post guys, thank you. Just had the same problem, BMW quoted up over 200.00 got the part recommended for 12.99. Thanks again.
Old 03-25-2009, 06:27 PM
Latoilette Latoilette is offline
Send a message via AIM to Latoilette
Mein Auto: 2002 330ci silver
B/c you guys helped out so much, I will throw in a tip or so.
********secret of not draining washer fluid************ my reservoir tank was full, and I got to reuse them all.
here's how.
First take off sensor in the bottom (towards the car).
take off electric connection to the pump.
when you undo the line that is attached to the pump, put your fingers there. Then, lift up the whole reservior tank, empty washer fluid into a bucket.
Old 03-28-2009, 01:42 AM
fchen83 fchen83 is offline
Mein Auto: 2001 325i
Thumbs up
Thanks for the info people. Just bought a used bimmer and this was the first thing I noticed that wasn't working. $23 later I'm squirting washer fluid everywhere...now I just need to aim them suckers.
Old 04-07-2009, 01:49 PM
23 dollars later? what do you mean? did you get the genuine part instead of autozone one?
Old 04-12-2009, 03:47 PM
Mein Auto: e46
Just replaced mines 10 minutes, follow the pictures from the first post and it was a piece of cake. Ordered the siemens washer pump and new grommet from partsgeek.com Can't believe I was driving around for almost a whole year with a defective washer pump ....
Old 05-14-2009, 01:30 PM
bmw330pp's Avatar
bmw330pp bmw330pp is offline
bmw330pp
Mein Auto: 04 330Ci ZHP, 06 CBR600RR
I made a gasket and jammed it into the little sqaure opening at the bottom of the pump and the leak stopped... Will clogging that opening cause any problems?
2004 330ci, Silver ZHP, Xenons, Sunroof
Old 07-07-2009, 03:43 AM
325i M-sport II 325i M-sport II is offline
Mein Auto: 2002 325i M-sport II
My washer pump started leaking from the weep[square] hole yesterday. It is the second time to have this problem. I replaced the first one from dealer in 2007 and costed me $57. How's your self made gasket, is it still working after a month?
Old 07-20-2009, 05:00 PM
bmw330pp's Avatar
bmw330pp
Yeah, I've used the washers and they work fine...
Old 07-23-2009, 07:46 PM
Thanks and I will do the same to clogging the weet hole by a gasket. It's not worth to replace the pump as it works fine (but just leaking from the weet hole).
Old 08-04-2009, 01:20 PM
veschallenberg veschallenberg is offline
Mein Auto: BMW 325i
Pictures speak 1000 words
Not being much of a DIY'er, the pictures, illustrations, helped greatly. Start to finish time 1 hour. Only mistake I think I made, was purchasing the pump and strainer from the dealership for around $60.00. Hopefully I saved that much on labor.
Old 08-15-2009, 02:27 PM
don4texas don4texas is offline
Mein Auto: 325i
Cut out the original connector for better connection. I tried using the connectors provided with the Autozone pump and they don't provide good enough connections.
Old 10-14-2009, 06:16 AM
Mark_325i's Avatar
Mark_325i Mark_325i is offline
Mein Auto: '03 325i, '88 325iC
Another "thank you" for this writeup. I bought my pump on Ebay for $20 (inc shipping and tax). The seller was deutschepartsusa (deutschepartsusa@gmail.com). My car has the CWP, so there is another pump in the front of the reservoir (by the headlamp). Make sure you change the correct one! In retrospect, I could have swapped the two pumps as I disconnected the headlamp washers soon after I bought the car -- I did not like all of that fluid spraying over the hood.
Mark
88 325iC
03 325i
Old 10-14-2009, 06:03 PM
wpmcnamara wpmcnamara is offline
Mein Auto: 2002 330i
About as easy as they come, but thanks for the write up. Saves a bit of time figuring it out.
Unfortunately, it didn't fix my problem. I replaced the pump, but still have no fluid. Checking the pump connector with a voltmeter shows ~9V regardless of whether the key is on, or the wiper stick depressed.
I've checked all the fuses that look anything related (at least according to the labels) and they are all ok. This all started with taking it to the dealer for something unrelated (burnt out the tranny) and of course, while it was there, they go over everything. It was noted as a leak in the windshield washer pump. Then the next time it rained, I went to clean the windshield and no fluid. After reading here and elsewhere, it seems that it is not unusual for the pump to fail once it starts leaking. No bigger, ordered the pump and replaced it this evening. No dice. RealOEM isn't very good for troubleshooting electrical problems so I am at something of a loss where to go next.
Any suggestions?
*ninja edit* I found another thread detailing almost my exact symptoms: http://forum.e46fanatics.com/showthr...1#post10762760
Old 12-30-2009, 03:22 PM
mtnbound mtnbound is offline
Topless Expert
Mein Auto: 330 Vert
Another big THANK YOU. My pump failed and I was given an estimate of $110 to replace it. Heading to Autozone now to spend less than $20!
Old 01-02-2010, 08:05 AM
Mark_325i's Avatar
It's even easier if you get an OEM pump off ebay -- no cutting of electrical connectors.
Mark
88 325iC
03 325i
Old 01-02-2010, 09:31 PM
tcphoto tcphoto is offline
Mein Auto: '01 325Cic TiAg
I just bought a used 325CIC and found that the wiper solution is not working. I got the usual response from the Dealer, "I'm with a customer, can I call you back?" What a DB, a week later and I will be going to ebay and picking up a pump. Great write up, I'll have to brave the 35 degree weather and get this thing running. Will I lose all the fluid that is in the tank?
Old 01-14-2010, 10:24 AM
Installed the ebay motor in about ten minutes including testing, wiping the area clean and installing new wiper blades. I had a bucket next to the vehicle and emptied the tank when I pulled it out and recycled the solution.
Old 01-18-2010, 06:02 PM
wardly wardly is offline
Mein Auto: 2004 330i
Autozone pump/help
A few of you commented on the fact that the Autozone pump did not have as much pressure and you took it out. The same has happened to me--it seems to work but it certainly doesn't shoot the water as high up on the windshield and a lot ends up on the hood.
If I want to take this out and return it and get an original part. But using those scotch locks on the wires--can I just take these off or am I going to have to cut the wires and reconnect them to the original connector?
For those of you that the Autozone pump worked--did you not have the pressure problem?
Similar Threads
OEM Washer Fluid Plaz General BMW 122 12-13-2008 11:56 AM
New Info on e46 M3 Bearings/oil pump service bulletin MUST READ TGray5 M Series 5 12-03-2007 09:08 PM
Windshield Washer Fluid - Vanishing - matt_328is E36 (1991 - 1999) 3 03-05-2005 06:35 AM
Replacing Smog Pump/Secondary Air Pump - DIY? BrettInLJ 5 Series 3 02-08-2005 03:57 PM
clear windshield washer fluid found..... 31st330i 3 Series / 4 Series 1 06-03-2002 12:13 AM
