Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Door pannel fix
This is a simple way to fix you sagging or lose door card. I spent about 10 min doing everything, the only catch is that you will need to let the adheasive cure or dry.
Removal: The pannel is fastened by clips and screws, there are 2 screws tucked behind the handle on the arm rest, simply pop the covers off and unscrew them, after that just pull the door card off and unplug the speakers, the speaker wires pull right out, don't be to aggresive though as you may damage them. Things you'll need once the door pannel is off: Pliers, and RTV silicone. This is what it looked like before I took it off the car This is what the repair did Once I examined the door I found what the cause was. There is a plastic molding holding the door clips that was glued to the door card and had seperated itself due to many opening and closings. Some of the clips were broken as well. I recomend purchasing new ones from the dealer, don't be a cheap wad. You should have these clips before the repair so that you can do everything at once. To remove the clips simply wist and pull them with pliers, they are notched and are designed to be done that way. Remove the clips before you decide to apply the adheasive as this may cause some issues later on in the repair. To put new clips in, just twist them in with your fingers, it doesn't take much effort. Next you simply apply the adheasive thoroughly. Cleaning shouldn't really be an issue, but if you decide to clean the area, use a mild soap and warm water. Push down on the plastic to spread the silicone around, you don't need to smooth it, let the plastic do the work for you, plus you don't get dirty. Thats pretty much it for the repair, the next thing you'll want to do is apply pressure. I chose to use a piece of cylinder poly and laid my amp on it. You'll want to have adequate pressure to ensure a tight bond. When you add the weight, have the door pannel somewhere that will be out of ways harm. I chose the coffee table.... ![]() Let the RTV dry before you mount it back on the car. I let mine sit over night just to be safe. Simply reverse the removal process to re-attach the door pannel...and your finished Hope this helps, it's super easy and cheap, it's not the most interesting thing in the world but I needed it fixed so I'm sure someone else does to. If you guys think I left somehting out then let me know but I think I covered everything.
Hey, great contribution!
This is a very common problem. You should think about submitting this to some of the BMW DIY sites so other e36ers can benefit.
BMW 3 Series - "Consistency of Purpose...Excellence of Execution." ![]() Supercharged E36 325is 5sp ![]() ::ERT S/C, Auto-Manual Conv, SPAL Fan, Zeitronix, SAFCII, Alpine, Autotek, Orion, Angel Eyes, Tinted, Smoked, Trackpiped, and so much more:: Drop Top E46 330cic Step ![]() ::PP, SPP, CWP, HK, BT, Lumbar, Xenon, Tints, Clears, Remus Exhaust, ///M-Tech Wheels:: |
Thanks for posting this! I need to do the same thing, have even bought the plastic clips, but have just been putting it off for ages. Hopefully my experience will be as painless as yours.
Good idea....I looked on bimmerdiy and didn't see one there, so I submited it...maybe they'll host it. this was the easiest repair I've ever done....didn't get dirty and it was cheap....gotta love fixes like that.
Keith Quote:
Thanks for the post. Mine isnt as bad as that but I will look into this when I redo my door handle seals.
Thanks. I haven't had any issues with it either since the repair was completed, nor do I think I will
What is RTV silicone. I can't seem to find it any where. Can you substitute with another kind of silicone?
this is perfect i just brought a 318i and my drivers doors is just like this an i was not sure y as the clips seem to be in place.
tell me tho are the clips universal or bmw only coz we have an auto spares shop who will prob do them cheaper (i did read the cheap wad bit but chose to ignore) lol ty again |
I repaired the doors on my '94 325iC using hot glue and it worked very well. I took them off to unplug the lousy sounding middle speaker and when I did they fell apart. The inserts on my car aren't plastic but are the same material as the door panel. I had a hot glue gun and plenty of glue sticks so I chose to use them. The plastic inserts at the bottom also adhered very well with the hot glue.
nice, I need to do this to my car as well, but i'm just too lazy to do so, probably in a month or so i'll finally get up and do it.
Did you buy new clips or were yours re usable. |
i just done myn 2day it worked well the top part of myn have come away tho not the bit dwn the side i brought 11 new clips and did nto need to use any of them
thanks tho good job all done. Last edited by m3 tkd; 06-08-2006 at 03:39 PM. |
You missed a spot, but great work!
There is a clip panel at the TOP of the door as well. This usually separates, particularly when removing the door panel. Many assume (as I did, initially) that this was part of the door, as it separates so cleanly that you don't realize it was originally glued to the door panel.
Remove the interior window weatherstrip (pull straight up) and then carefully pull this piece out. Then glue it in place to the door panel (it will fit like a glove in the right location). RTV silicone, like you used, is the best. I used a latex adhesive caulk (which I had laying around) and that worked OK, too. IN short, the door is held in on all four sides: Front and rear with the clip strips (as you show), at the top with a clip rail, and at the bottom with the storage compartments. Make sure all FOUR items are properly glued in place. Once reinstalled, re-insert the window interior rubber gasket, and if you align it carefully, it will fill in the space between the door panel and the window just like the day it left the factory. Here are some more pictures at: http://good-times.webshots.com/album/557789582nyYUxv Goog Luck! --Bob. |
I am about to attempt to replace the drivers side window motor on my vert.
Any hints tips or tricks I need to be aware of? I am concerned that my motor and regulator are riveted in and that I will have to drill it out. Anyone have any experience with using a bolt to reattach them after drilling out a rivet? |
Check the manual
I'd be suprised if the motor does not snap out like the power door lock actuator. I did this repair on my old Toyota, and the crank mechanism was riveted in, but the motor pack was a snap-on affair. Took 2 seconds once I got the door panel off.
Check your bently manual to be sure. Expect to repair the door panel as I did (and the other posters did) as the clip strips will probably separate from the door panel. Allow a day for the glue to harden. And don't forget that top strip. It is NOT part of the door... |
i door panels are smae condition as yours, this is gonna come handy. A+! |
can it work on e21 doors it have wood ?
Top mounting bracket
Teen daughter's 1995 325is:
We bought the car used and are having the "normal" door panel problem. I am fixing the driver door panel this weekend, but the top plastic piece is badly broken and needs to be replaced. Has anybody had luck finding or fabricating one (or are you just putting the panel back together without the top piece if it's real broken)? Thanks!!! |
Every BMW ive had has had a knackered or loose door card, really lets down older BMW's
Mark |
![]() All of my plastic bits need re-attaching and even the map holders on bottom of the door. You don't have to use silicon, if you have a hot glue gun(big one) use that, or any good glue that is designed for the job...ie not super glue or wood glue ![]() With the top plastic piece, mine was snapped in 2 almost 3 places and when re-attached it is no problems at all.
I think I need to do it too.
thanks someguy |
Good job on the guide. I recently did this fix too when I replaced my door lock actuator. For those looking for an alternative adhesive I used
Scotia & Skirting Fixing Adhesive. ![]() It is used for glueing skirting boards on - grips very tightly but allows a bit of flex. So far it is holding up well. If you are in the UK you can get it from B&Q. Last edited by -Matt-; 06-01-2008 at 04:30 PM. |
great write up! I'm going to do this very soon! I'm still looking for a DIY on when the leather becomes loose on the door panels if anyone knows where that is....
Went thru all of the glueing, stretching of vinyl and clamping but door would not stay on anyway. The cardboard looking stuff inside the door had softened to where the clips just pulled out in a few places. We solved it by drilling a small hole thru the door panel and anchoring a 2" screw in a drywall anchor. Not ideal but doesn't look too bad and the doorpanel stays tight. to reglue the vinyl I used a blowdryer to stretch the material and then glued it in place with silicone. Looks WAY better than before.
#25
Click HERE when I tell you to go to my damn Sticky. It saves me time and you a tongue lashing. Member of the Non-M Bumper By Choice Club
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cold Air Intake - Need Data for Fix Developement | Maddawg58 | E46 (1999 - 2006) | 24 | 03-28-2005 07:27 PM |
| E30 Auxiliary Electric Fan wiring fix | kowached | Do-It-Yourself H.Q. | 0 | 10-14-2003 06:26 PM |
| LONG --- Another Happy Sticky Pedal Fix Customer!!!! | The BoatMan | 3 Series | 20 | 08-08-2003 02:51 PM |
| sticky pedal fix | g3kamdbs | 3 Series | 0 | 12-26-2002 02:50 PM |
| Drive by Wire throttle fix info | WAM | General BMW | 34 | 08-09-2002 04:27 AM |
