What does the "Active Driver Assistant" do? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 11-12-2017, 11:34 AM
eksath eksath is offline
Mein Auto: '02 330ci
Hi All,
Anyone have the ZBD package alone on their car? What does the "Active Driver Assistant" do?
This is for a 2017 230i.
thanks.
Name:	Screen Shot 2017-11-12 at 1.32.10 PM.png
2002 ED E46 330CI
2018 PDC Awaiting date
Truth comes in three stages. First, it is ridiculed. Then, it is violently attacked. Then it becomes self evident.
Old 11-12-2017, 02:15 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Shakes the steering wheel when you change lanes without signalling, pre-loads the brakes and slows you down somewhat if you're about to tap a car at city speeds, and hits the brakes if the camera detects a pedestrian in front of you.
Old 11-13-2017, 04:03 AM
Thank you!
2002 ED E46 330CI
