E34 (1989 - 1995)
Old 10-13-2005, 02:02 PM
hairywankanobe hairywankanobe is offline
Hairywankanobe
Mein Auto: 535i SE
Difficult to start then misfires alot then is ok
Hi,
I have a 1989 535i SE which has an intermittent fault. Some times it is really difficult to start and when it does get started it misfires really badly but after driving for about 20 minutes to an hour it sorts it's self out and drives fine. It doesn't do this every time. I was thinking it could be moisture getting into the ignition system either in the distributor cap or somewhere in the ECU. I've ordered new plugs, leads, distributor cap and rotor arm to see if that helps. Has anyone had similar problems, and if so, how did you cure them?
Old 10-13-2005, 03:29 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
that all may fix your problem... but check out these two sites and post back your results...
http://www.bimmer.info/forum/forumdisplay.php?f=10
http://www.bmwe34.net/E34main.htm
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
***help, Car Won't Start - Possible Engine Flood!!!*** bmw_reloaded E34 (1989 - 1995) 13 07-24-2007 03:27 PM
Bimmer Ownership Phases... (Very very long) FSelekler General BMW Questions 31 02-08-2006 02:36 PM
Help! 325ix Won't start. nolancumings E30 (1982 - 1993) 1 04-24-2005 03:21 PM
cold start clinking noise sj-02-325Cic 3 Series & 4 Series 13 04-05-2002 10:02 PM
