Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 10-14-2005, 12:08 PM
5gm 5gm is offline
Mein Auto: m3
missfire help
hi,
can anyone help.
i have a 98 m3 evo (S50) which has an intermitent missfire at high rpm when on full throttle, it normaly starts at about 5500 rpm & sometimes it will not rev above 6000 at all.
i have pluged in my scanner to check the fault codes & it comes up with missfire at coil cyl 3 & 4 (codes 24 & 50). i then tryed swaping the coil packs from cyl 3 & 4 with 1 & 2 to see if the fault changed cylinders but it stil says 3 & 4.
whenever i clear the fault codes it will not missfire at all for a few days & then it will do it randomly.
any help would be apreciated.
thanks
Similar Threads
missfire at high rpm. help 5gm E36 M3 (1995-1999) 1 10-15-2005 12:12 PM
Please help... missfire bunilla E46 (1999 - 2006) 3 01-20-2005 11:15 PM
