128i misfiring even after tunning up - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
Old 11-14-2017, 06:53 PM
Megaromania Megaromania is offline
Mein Auto: 128i
Hello everyone I am new here
I have a 2008 128i that keeps throwing a cylinder 1 misfire.
I changed the coil and the spark plug still keeps on coming back
Did a compression test and no issues
It looks like it happens only when I turn on the car.
Its not really a bad misfiring you don't even feel it the car drives smooth.
Any ideas what it might be?
Old 11-15-2017, 12:33 PM
jsenne jsenne is offline
Mein Auto: 2012 BMW 128i Coupe
Check for Pending Codes
I recently had to fix a few things on my 2012 128i.
- The car misfired at a cold start pretty badly but then went to normal after about 5-10 seconds.
- Misfired at idle when at a stoplight or accelerating from idle.
BMW Dealer Analysis:
- Eccentric Valvetronic Shaft Sensor (Causing rough idle at cold starts)
- Needed a new battery.
Total repair cost = 2224.00
Now, they fixed these two things, but I still had the damn misfire or "hiccup" at idle when at a light or stop sign after warming up. Instead of bringing it back in. I just changed the coils myself and the problem was fixed. Runs like a dream now. It sounds like your valvetronic shaft sensor could be bad. If you have an OBDII you can check for a P1017 code that might be pending and hasn't triggered the engine light.
Joshua S.
