E46 M3 (2001-2006)
Old 10-18-2005, 12:34 AM
Paul_88 Paul_88 is offline
Mein Auto: M3 Cabrio
Suspension Question !!!
What's the impression on KW V2 coilver on your M3 ?
Pros and cons .
what's the best place to get them and what price range .
thanks
Old 10-18-2005, 04:54 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I have never tried the KW, but a friend has them on this M Roadster and is pretty happy with them.
I just installed TC Kline setup. VERY nice compromise for street and track use. Handles better than stock, and actually rides better than stock. Reset the shocks and it does nicely on autocross or track.
Koni double adjustables, with threaded front bodies, 400 pound/inch springs all around, rear adjusters, rubber rear shock mounts, and camber plates. About $2600.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-18-2005, 09:23 PM
thenobot thenobot is offline
Mein Auto: 98 M3/4, 05 M3 ZCP
Originally Posted by Pinecone
I just installed TC Kline setup. .... About $2600.
Ground Control's DA setup is about $500 less than the TC Kline kit. If you considered it, what were the attributes of the TCK kit that led you to your purchase?
Old 10-18-2005, 10:01 PM
safetywork safetywork is offline
Mein Auto: '04 E46 M3 (6 sp)
Pros and cons .
thanks
I like the KW V2's. I had PSS9s before I switched (PSS9s were too soft for track duty). The KW's do ride stiffer then the PSS9s so you'll have to adjust them to your liking. KW's have more stiff, stiffer, hard, and rock solid settings then soft settings. The KWs are adjusted by an allen key so you'll have to rotate to one side all the way then count how many turns and do the same to the other side. The good thing is you don't have to get under the car to make the adjustment. The bad is you'll have to make a cut in the trunk liner in order to get to the adjustment.
So far, I like the KW's better the PSS9s. As others have stated, the GC and Tien's have been getting great reviews. You may want to investigate a bit more.
Charles H.
'08 E60 550i (6MT, Sports Pkg, Comfort Access, Winter Pkg, Nav)
Old 10-19-2005, 12:48 AM
I'm just using it for street use .
so the kw will do the job right ?
Old 10-19-2005, 05:53 AM
trentmw trentmw is offline
Transporter
Mein Auto: E39 528iT & SPEC E30
If you are just using it for street I would have to recommend the TC Kline setup. As pinecone says it handles better than stock and is much smoother over the rough stuff. TC gave us his Comp Pkg M3 w/the setup that pinecone stated at O'Fest and told us to have fun. It was very strange driving around looking for speedbumps, potholes, road irregularities, etc. It handled them all extremely well with improved handling over stock(shocks set at lightest setting). TC definately made out good as 3 people bought kits from that one drive.
Old 10-19-2005, 06:24 AM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
Coil overs are overkill for street use. Just get some Koni S/A shocks and springs.
Old 10-20-2005, 05:08 AM
Pinecone's Avatar
M Mad
a) GC doesn't include rear shock mounts ($90 for GC, $129 for TC Kline ones).
b) GC kit uses SINGLE adjustable rear shocks. "Pre adjusted to spring rate". TC Kline uses Double Adjustable rear shock, top adjustable for rebound, bottom side adjsutable for compression.
c) TC Kline shocks are costom valved and made by Koni for their use.
d) TC Kline uses custom designed springs that allows you to swap springs without changing ride height and corner weights. So you can go to the track, swap in higher rate rear springs, reset the shocks, pop on your R-comps and have a more track tuned suspension. Reverse for dirivng home. Basically the free lengths change for the different rates. But rear spring swap is obtional, the car does very well with 400 pound springs all around.
e) TC Kline answers their phone every time I have called. And the people you talk to all know their stuff, where at GC you really need to talk to Jay. Which can be hard at times. But Jay really knows his stuff.
f) TC Kline gave us a bit of a deal on buying more than one suspension at a time. True, I did not ask GC, but TC was standing there when a friend drove the car, and offered free shipping.
But the GC setup is very nice, and I like their stuff. And I would have been happy to get their stuff, and have recommended to others. And advantage, GC has a wider range of srping rates to play with.
It was just that I got to DRIVE TC Kline's car and liked the ride and handling. I watched TC run the O'fest autocross and the car was sweet through the transitions and very fast overall. I saw the car on the track and it performed well, and I got to drive the car, and with the same setup used for track and autoX (except for shock settings) the car rode better than my M3 with stock springs and S/A Konis (pre-adjusted by GC for use with stock springs). And it still handled better than stock. I did not have a chance to drive a properly setup GC car. They need to be at O'fest next time with demo cars.
Bottom line, you will not go wrong with EITHER setup.
If I were going to do a pure track car, or race car, I would probably have gone with GC, but with Advanced Design shocks, unless teh budget would allow Motons or Phlins.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-20-2005, 05:11 AM
Pinecone's Avatar
M Mad
I disagree. I have that setup, and the TC Kline with 400 pound springs rides better than stock, even lower and on 19s. And handles better.
You need to drive one of the cars this weekend with this setup. It is SWEET. You are running stiffer springs.
Downside of the TC Kline setup is you cannot slam the car, if that is what you want.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-20-2005, 06:14 AM
bren's Avatar
///Mpty pockets
I disagree. I have that setup....
Not with aftermarket springs
Old 10-20-2005, 06:17 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
And FWIW, Terry, you can only swap springs without altering corner weights much if you're around 700-750lbs. per corner.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 10-20-2005, 03:22 PM
SteveT's Avatar
SteveT SteveT is offline
Mein Auto: '08 E92 M3/'11 X6 3.5
Anyone have thoughts/experience with the H&R Springs coil over?
SteveT
2008 E92 M3 - SSII/Fox Red
2011X6 3.5 - AW/Red/Alcantara/Leather
BMW CCA
Old 10-20-2005, 07:11 PM
bren's Avatar
///Mpty pockets
There have been A LOT of complaints about the adjusters breaking. There really is no good reason to not go with TCK or GC.
Old 10-21-2005, 02:24 AM
Pinecone's Avatar
M Mad
True, but I do have aftermarket springs on the LTW with D/A Konis.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-21-2005, 02:25 AM
Pinecone's Avatar
M Mad
Also they are VERY stiff, much more track than street oriented. PSS(s are the other way, the springs are way soft, much too soft for good track performance.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Pinecone's Avatar
M Mad
Not according to TC.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-31-2005, 09:48 PM
ClubSpec330i ClubSpec330i is offline
The 1st 'Fest attendee..
Mein Auto: BMWs
Having been in both proper prepared GC and TCKR M3, I have come to this conclusion;
GC is spring bias-let the spring do the work
TCKR is shock bias-let the shock do the work
I was leaning toward GC at first but after a great deal of seat time in TCKR, I am leaning the otherway.
It would be nice to put shock-dyno of Konis from both camp compare to off the shelf Konis. I wonder if all three will be the same or all different.
Old 11-02-2005, 05:53 PM
Pinecone's Avatar
M Mad
Again, the nice thing about the TCK setup, is you can switch from street to track by chaing shock settings. Perfect? No, but it works well for a dual purpose car.
And be swapping in 500 pound springs in the back, it works even better.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 11-03-2005, 09:07 PM
a..f)
cool, thanks for the explanation.
to correct one point, i received rear shock mounts with my GC kit. (koni s/a street/track kit $1849)
Old 11-05-2005, 04:16 AM
Pinecone's Avatar
M Mad
Cool, they are not listed as coming with the kit.
Nothing at all worng with the GC setup. Or the TCK, they are both very nice setups.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 11-12-2005, 07:02 PM
FITZUNI's Avatar
FITZUNI FITZUNI is offline
Send a message via AIM to FITZUNI
Mein Auto: 04 BMW X5 4.8is
Go With The Tc D/a
2004 X5 4.8is
2003 M3 SMG. SOLD
2002 TT MTM
Old 11-16-2005, 08:16 AM
JPinTO JPinTO is offline
2001 M3:Stick, what else?
Mein Auto: ///MMMmmm good
I'm not sure that your statement is going to hold true for everyone, it really is up to personal preferences. I replaced my shot OEM's with the Koni's this spring, not wishing to spend the $'s on coilovers.
After 6 months, even on the hardest setting, they are squishier than I would like them. I've only done 1 driving event, so this I'm pretty much 99.9% street use. I wish I handn't wasted my money on the Koni's, as I'm going to have to by coilovers at some point.
Old 11-16-2005, 08:26 AM
Whatever. Go ahead and measure the spring lengths and do the math.
Old 11-16-2005, 08:28 AM
No, they just have incredibly crappy damper and spring settings. It's not track oriented. The H&Rs just suck.
Old 11-16-2005, 08:44 AM
bren's Avatar
///Mpty pockets
Of course there are always exceptions.
The original poster sounded as if he was content with the OE ride and simply wanted to lower the car. In that case Konis and springs are a fine option.
Similar Threads
E39 528iT suspension question waydeki Tire Rack's Tires, Wheels, Brakes & Suspension 1 01-17-2011 12:36 PM
Sport Package suspension question... hecklerz 3 Series & 4 Series 2 12-30-2004 09:09 PM
Suspension question 325CI BeamerDaddy2001 3 Series & 4 Series 18 09-12-2002 11:29 AM
suspension question AC E36/7 Z3 (1996-2002) 5 07-15-2002 02:05 PM
Suspension question daven E36/7 Z3 (1996-2002) 4 07-14-2002 03:25 PM
