E36 (1991 - 1999)
Old 10-21-2005, 06:27 PM
shassan446 shassan446 is offline
Mein Auto: ny
i need to replace my starter
should i tackle it myself, anyone have directions.........96 328 is
Old 10-21-2005, 07:12 PM
ronin325i ronin325i is offline
Mein Auto: 325i e36
i am a tech for bmw and i will tell you that it is a HARD job. i had to do mine and i wanted to kill some one but it will cost you to have some one else do it.
Old 10-22-2005, 06:20 AM
Dudesky_E36's Avatar
Dudesky_E36 Dudesky_E36 is offline
Run Far
Mein Auto: 2001 Anthracite 530iA
Yea, seriously, good luck . . it's worth it to have someone else do it because of where it's located
Old 10-22-2005, 06:39 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
If it's in the same spot as the E46, you might as well get your clutch done, too.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 10-22-2005, 09:45 AM
1fast325i's Avatar
1fast325i 1fast325i is offline
Neverending Top End!
Mein Auto: 1998 540i Sport
As what everyone said, it's a tough job and time consuming. I had to replace my starter three months ago and it was a pain in the @$$! My father in law and I worked on it the whole day. The first thing you have to do is remove all the parts that gets in the way to access to the starter. Your throttle body, intake, throttle cable, etc. Then lift your car up to access your transmission under your car. Make sure you have a tranny stand to put under your tranny to bring it down slowly. You have to loosen the bolts that hold your tranny up and drop it down to a certain point then retighten the bolts to ensure it's secure again. Looking from the back to front of the tranny, you will see an opening about 3 to 5 inches on top where you'll see a bolt. That bolt is what holds the starter. Remove the bolt, the positive cable that's attached to it and pull the starter off. At this point, prepare the new starter to be installed. Ensure to test it first to make sure it works if you bought it from a pick in pull shop. You don't want to redo all that hard labor twice. The easy part is done, here's the hard part. Depending if your starter has the permanent nut attached to it, this will make it easier to rebolt on. Make sure every thing that you dettached earlier are reattached. Put the tranny back up and retighten.
Old 10-22-2005, 10:03 AM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
Originally Posted by 1fast325i
...Your throttle body, intake, throttle cable, etc...
If the E36 is anything like the E46, I'd question the necessity to remove these. I believe on the E46, the job is done from the bottom of the car. Don't know if the tranny has to come off, but I think it does at least need to be tilted to access the starter bolts on the bell housing. Not positive though.
I'd consult a Bentley manual or TIS. Good luck to the OP.
Old 01-20-2008, 11:19 AM
richpentney richpentney is offline
Mein Auto: E46
I did mine a few months ago. It was a pain to do. We had to lift the car up, lower the exhaust and the lower 1/2 of the tranny to get at. I believe we had to use 3 feet of extensions to even get at the bolts!
Similar Threads
Starter Relay Location - 89 325i dave collin E30 (1982 - 1993) 0 08-11-2005 09:00 AM
starter motor rebuild greg _mustang 5 Series DIY 1 02-28-2005 02:04 PM
1984 318i Starter problem... MDMark16dc 3 Series & 4 Series 4 07-12-2004 09:07 PM
How many tires to replace? jw Tire Rack's Tires, Wheels, Brakes & Suspension 10 02-14-2004 12:38 PM
About to replace driveshaft, questions DanB 5 Series DIY 7 01-24-2004 02:15 AM
