missfire all cylinders - Bimmerfest - BMW Forums
Old 11-29-2017, 12:36 PM
AbedN55 AbedN55 is offline
Mein Auto: 435i f32
i got bmw 435i 2015 i got on it 30.000mi and its works fine but before 7000mi i done on it custom tune to the car ecu to get stage 2+ i got on it afe filter new bigger intercooler charge pipe down pipe every thing that it will need so in the last 2 month im in big problem i went to bmw dealership to check it to every one that knows bmw like his life! so they saied coils plugs and in some moment i changed injector and the problem still every time i kick the throttle at 3.5rpm with the turbo opens the car wont accelerate and i have drivetrain problem!
and before one week i got a tip about something to do for problems like those and i stoped the car raise to 3.5 rpm for 5 min then the rpm went to 2 rpm and its ot responding like no power or a limit and i cant raise more thab 2 rpm i waited 1 min the i tried this again i raised to 3.5rpm and in just 2 min the same went to 2 rpm no response !
i checked the electricity on the the air and its pretty good and the furl works fine please guys any thing i can try i tried every thing so if you say any i will try!
note (im removing the tune to put jb4)
and upgrading the fuel pump i heared maybe its the problem!
Sent from my SM-G935F using Bimmerfest mobile app
Old 12-04-2017, 05:36 AM
jgoens's Avatar
jgoens jgoens is offline
Mein Auto: 2013 335i
Reading that made me dizzy.
Sent from my SAMSUNG-SM-G935A using Bimmerfest mobile app
2013 335i Msport Black Sapphire/Coral red. JB4. VRSF DP, ER CP, various codings.
Previous car: 2011 Msport 335i JB4 VRSF CP,
Old 12-04-2017, 06:12 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
I imagine if you were to try to explain something in technical terms in his language you would make him dizzy.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 12-04-2017, 07:58 AM
Robin128 Robin128 is offline
Send a message via ICQ to Robin128
Mein Auto: 340i M Sport 8AT
Cut an inch off the tail pipe.
One should treat others as one would like others to treat oneself.
Old 12-06-2017, 10:48 AM
mike@x-ph.com mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Sounds like your custom tune is the problem. It is also too aggressive for your mods, not safe to run a map when you plugs/fuel pump cant keep up.
Go with a proven solution like the jB4
https://www.x-ph.com/burger-tuning-b...eries-n55-jb4/
