E34 (1989 - 1995)
Old 10-27-2005, 08:06 AM
dlloyd1975's Avatar
dlloyd1975 dlloyd1975 is offline
IRIX Rocks!
Send a message via Yahoo to dlloyd1975
Mein Auto: 325iT Schlampenschlepper
What to look for in an used e34
I may end up going back to commuting to work soon, so I've been looking around
for a halfway decent commuter car. I was thinking about a used 525i with a
manual transmission. Anyone know a pointer to a list of things to look out
for in e34s?
--dlloyd1975
The Shaggin' Wagon
2003 Gray Green 325iT, PP, SP, CW, HK, Sand 'Ette
Old 10-31-2005, 11:58 AM
Jaz525i Jaz525i is offline
Mein Auto: 93 525i / 85 Mustang GT
I just bought a 93 525i w 127k for an everyday driver as I've seen them go many more miles. My neighbor had a 1990 that he drove to 319k!!!
Initially, my car had a clunk coming from the front suspension when I let off the brake pedal... turned out to be the thrust arms and bushings. Also had a vibration when I was on the highway. The flexdisk (Guibo?) on the driveshaft was shredded. Did the alignment afterwards and the car now drives real smooth.
I've heard the the auto trannys go for a while. The brakes are phenominal in these things and takes turns with confidence. Theres supposed to be a bushing or spring absorber in the rear shock towers that causes a clunk when it wears down. Other than that, Im a Newbie here so still researching these cars. Im sure I'll discover more soon.
Good Luck!
Old 11-01-2005, 04:37 AM
EJ EJ is offline
Mein Auto: 94 530i
Check here http://bimmer.roadfly.com/bmw/forums/e34/ and http://www.bmwe34.net/e34main/troubl...will_break.htm
Old 11-02-2005, 09:18 AM
dlloyd1975's Avatar
IRIX Rocks!
So, it looks like anything in the suspension that's made from rubber will have to be replaced, plus water pump and wheel bearings. Maybe some other stuff depending on which engine is in the car. So, maybe more than you'd care to do on the same vintage Japanese or American car, but probably not something outside the realm of the competent DIYer.
--dlloyd1975
The Shaggin' Wagon
Old 11-03-2005, 02:31 PM
EJ EJ is offline
Mein Auto: 94 530i
Yep that about sums it up. My mechanic says the 91-95 525i E34 and 93-95 325i E36 are the most reliable BMWs, even better then MB. He specializes in both.
Old 11-08-2005, 05:35 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
http://www.bimmer.info/forum/forumdisplay.php?f=10
the best place for the 525 e35 series information
Similar Threads
Who went from an E34 to an E39? What are your opinions on them? bimmerd00d E39 (1997 - 2003) 17 03-12-2010 07:16 PM
Dolphins fend off Great White attack! Jon Shafer Off-Topic 16 12-02-2004 09:19 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
E34 or E36 Michael330 General BMW 44 08-25-2002 05:59 AM
Toying with the idea of an E34 M5... Mr Paddle.Shift General BMW 12 05-13-2002 12:24 PM
