335is Limp Mode Symptoms - Bimmerfest - BMW Forums
Old 12-01-2017, 08:52 PM
B2Blain B2Blain is offline
Mein Auto: 335is
I don't encounter it during normal driving. When I need extra power to overtake another car it comes on. It clears when I turn off the engine. It will only come on when I need more power than normal.
I just purchased new tires and rims so I am dreading taking it in. I know it could be a number of things. But any hunches out there?
I am hoping for some type of a hose. I recently had the main fuel pump replaced. I am hoping its not a turbo issue or throttle actuator.
Old 12-01-2017, 08:59 PM
e92_dub e92_dub is offline
Mein Auto: 2011 335i
You're right.it could be many things.Are you able to diagnose/pull any codes?
Sent from my Pixel 2 using Bimmerfest mobile app
Old 12-01-2017, 09:34 PM
Mein Auto: 335is
I don't have a code reader. I was looking to get one on Amazon. But wasn't sure if it would be a good purchase if I am not going to fix it myself. I guess it would mainly be for peace of mind.
Old 12-01-2017, 09:42 PM
Getting a code reader is a Good idea imo even if you're not doing the repairs. you can research what's going on so when you take it to a place who's going to fix it you can some what validate what the repair place tells you is the problem.
Old 12-02-2017, 03:31 AM
allikanbe allikanbe is offline
Mein Auto: 2013 335is vert
Go to Advance Auto or Autozone. They usually will scan your car for free. It's just a hook up to your OBD.
Old 12-02-2017, 02:41 PM
Mein Auto: 335is
Thanks for the suggestion. I think I will buy a code reader anyway. Is there a difference in readers? I found one that does my model on Amazon. From what my repair guy says is that it gives you leads to the issue. When my fuel pump failed I had to bring it in more than once for him to diagnose the issue.
Old 12-02-2017, 03:38 PM
nate1970 nate1970 is offline
Mein Auto: 2011 335is convertible
Limp Mode
I've had two issues with my 2011 335is
Blown charge pipe caused the reduced power mode/light, it reset when I restarted and I could baby it and it wouldn't come on.
Service engine soon light came on and the car went into limp mode when I was accelerating. It reset when I shutdown. I replaced the coils and plugs and it went away.
Code reader would help.
Charge pipe covered under recall.
I had one mismatched coil, replaced coils and plugs from FCPEuro for about 210.
Old 12-02-2017, 03:43 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Mileage?
[code reader]
[charge pipe]
[intake valves]
Old 12-03-2017, 10:37 PM
Mein Auto: 335is
Originally Posted by CALWATERBOY DUE View Post
My mileage is about 45,000.
Old 12-04-2017, 01:59 PM
Mein Auto: 335is
Will these work to get at the hidden codes? Since my issue occurs when I accelerate over a certain point do I test it while driving? Or do I hook it up after the fault occurs and then connect it without turning the engine off?
https://www.amazon.com/Latest-Reader...mw+code+reader
https://www.amazon.com/MAOZUA-C110-L...e+reader&psc=1
Old 12-07-2017, 12:49 AM
Mein Auto: 335is
Anyone have suggestions on a code reader that an id "hidden" codes?
Old 12-07-2017, 10:33 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
I had a similar issue. Took it to BMW and they replaced the HPFP whited solved the issue. Weeks later my charge pipe cracked! Car runs solid now. I also changed the plugs.
There are similar issues with the injectors.
Take it to a good indy and they will sort it out. Or a dealer. My IS was covered for the HPFP and charge pipe (and injectors). 2011 with 45K miles.
Good luck.
