Lights malfunctions - Bimmerfest - BMW Forums
Old 12-02-2017, 09:03 AM
e93to e93to is offline
Mein Auto: 2011 E93 328i
Lights malfunctions
Started my car today, and these warnings came on:
What could have possibly caused this, and how could this be fixed?
Thanks in advance
2011 328i E93 - N52, Alpine White, Coral Red, ZSP, NAV, STEPTRONIC, Comfort Access, Heated Seats, Heated Steering Wheel, Through Loading. 06/10 build date. All stock. Original owner.
Old 12-02-2017, 09:42 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
So check the bulbs ...... if you have LED tail lights the whole unit has to be replaced to cure a failed LED .....
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
Old 12-02-2017, 10:15 AM
Yeah, it is LED bulbs. I just hope it is simple wiring issue.... It's strange both rear tail lamp and front signal light are out at the same time
Old 12-02-2017, 10:31 AM
"Left reverse light malfunction" is on as well... But left rear turn signal works
Old 12-02-2017, 11:46 AM
Would it harm the car if I wait until spring to fix this...? I am planning to replace wheel bearing and do some other minor works on the car in April or so. So I might as well do all of then together.
So I was wondering if these "lights malfunctions" would cause further damages if left unaddressed? My car will be hooked up to battery tender during winter. And it will be taken out for a work out once in 10 days or so when the roads are dry.
Thanks in advance
Old 12-02-2017, 01:00 PM
Cancar123 Cancar123 is offline
Mein Auto: Bmw f30
No worries it's just bulbs that went out could still be driven
Old 12-02-2017, 03:31 PM
Lights malfunctions
Thanks for your input. I'm worried that it could be an issue with wiring like corrosion... Not sure whether it would make sense to think it would cause more damages to other wires if left for a long period of time. Or maybe battery tender could have negative effects
Anyways. The front right turn signal initially works when engaged the first time after starting the car. And then I get the malfunction warning, and the signal stops working....
Old 12-02-2017, 08:54 PM
Django335d Django335d is offline
Mein Auto: 2011 335d
Bad bulbs
Sent from my SM-G892A using Bimmerfest mobile app
Old 12-03-2017, 01:21 PM
Originally Posted by Django335d View Post
Bad bulbs
Crap... That means it will be expensive to fix
Old 12-03-2017, 01:26 PM
How can the front turn signal AND rear lights (brake, reverse lamp, tail lamp) go out at the same time though? Wouldn't that mean some sort of wiring issue..?
Old 12-03-2017, 01:48 PM
Bulbs are cheap
Old 12-03-2017, 01:53 PM
Bulbs are cheap
Really? I thought LED's were expensive. Anyways, if true, that's good to hear!
Old 12-03-2017, 02:15 PM
laser's Avatar
So it seems you have a combination of light bulbs and LED .....for example ..... just the rear has two bulbs ..... brake light and running light ..... the turn signal is an LED (you said) ...... the whole rear light assembly is about US$50 ..... I just did mine ...
With multiple outages you probably need a shop evaluation unless you want to get a multimeter and self diagnose if you are getting voltage to the light assembly, if the whole assembly or just a bulb or LED has failed.
BMW front and rear light assemblies have a reputation for failing
Laser
Old 12-03-2017, 02:25 PM
Lights malfunctions
Hey, thanks for your input again. I really appreciate it
I thought the brake lights and rear running lights are LED's as well (LCI E93). But the reverse lamp is a conventional bulb. But the rear turn signal (LED) works... Strange
Anyways, can anyone knowledgable with schematics of wiring confirm left rear tail lamp housing is somehow connected to right front turn signal? I am very aware that these are prone to failure, but I am just surprised they went out at the same time... And they had to go out when I took out my car for last ride before winter!
Old 12-05-2017, 11:25 AM
Dealer quoted $1200 to fix this
Old 12-07-2017, 03:32 PM
WTF did they say was wrong?
Old 12-08-2017, 09:18 AM
Entire assembly for rear lights + labor + tax = $700. Front LED turn signal = $80. Running diagnostic on and checking wiring corrosion, faulty parts, loose assembly, etc = $400.
Old 12-08-2017, 09:19 AM
That's crazy.
