E30 (1982 - 1993)
Old 10-29-2005, 01:05 PM
Marty M Marty M is offline
Mein Auto: 1986 325e
Does anyone have a wiring diagram for the radio wires for the e30
Old 10-29-2005, 01:45 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
This was posted recently, might help.
http://www.bimmerfest.com/forums/sho...8&postcount=21
Old 11-10-2005, 10:24 AM
BMW325ICOUPE BMW325ICOUPE is offline
Officially Welcomed to the 'Fest!
Send a message via MSN to BMW325ICOUPE Send a message via Yahoo to BMW325ICOUPE
Mein Auto: 1990 BMW 325I COUPE
I have a 1990 325i someone has cut the plug off of the radio and wired in a 10 year old pioneer. The radio that was installed wouldn't turn off with the key, so i pulled it out and found the remote wire and began to remove the other wires to install a newer one. Now i can't seem to figure out what is what. I printed off the diafram that was above this post but i can't seem to figure out what to do with the speaker wires. Is there an oem amp in the car? Should i bypass it? What is an easy fix? i am somewhat affluent with aftermarket radios and harnesses but i cant seem to figure this one out. I need some help here guys, i know you know what you are talking about fill me in.
Old 11-10-2005, 10:28 AM
Just Bryce's Avatar
Just Bryce Just Bryce is offline
Mein Auto: Slammin Taco
It's the common ground that's probably throwing you off, I'm no expert but I have been doing my own installs for over 12 yrs and worked in a shop for a while. I got ticked with mine and just rewired all the speakers.
Old 11-10-2005, 12:22 PM
Orangefiv5's Avatar
Orangefiv5 Orangefiv5 is offline
Mein Auto: 1991 325i Convertible
Thanks for the repost misterlance. I have a 1991 325ic and I needed the wiring info as well. Thanks again.
Old 11-12-2005, 01:54 PM
schneller schneller is offline
Mein Auto: '93 325i
Are you sending power to the factory amp? (white wire). I thought I had everything wired correctly but was not getting any sound. I did have the speakers wired correctly, but was not turning the amp on. Connect the white wire to your radios remote power wire, and I'll bet you'll have it.
Old 10-14-2007, 12:47 PM
BadGoomba BadGoomba is offline
Mein Auto: green 1991 Bmw 325i
Yeah, like Just Bryce I also said screw the old wiring and rewired everything myself along with a new amp, sounds great now.
I think the old wiring degrades over time and causes noisy problems anyways.
The way they did the ground wires are odd.
Similar Threads
E30 Auxiliary Electric Fan wiring fix kowached Do-It-Yourself H.Q. 1 07-25-2012 08:35 PM
FS: E30 stromung, E30 Radio, E46 Remus, E46 Fox, E46 323 Rims nite_boy Classifieds 1 12-10-2004 11:48 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
E30 M3 Auxiliary Electric Fan wiring fix kowached 1M & M2 1 10-19-2003 01:55 PM
e30 radio coup83 3 Series & 4 Series 0 09-03-2003 09:41 PM
