E30 (1982 - 1993)
Old 10-29-2005, 07:51 PM
metrix2025 metrix2025 is offline
Mein Auto: 86 325e
cold start problems
Ok, i've got a 1986 325e and when i start it up cold if i don't add gas the idle drops and the engine shuts off
it doesn't have this problem when its warmed up and then i turn it off and on again.
just got the car, kinda new at this ....have mercy
Old 10-29-2005, 08:22 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
#1 You got to get the Bentley manual.
#2 its your cold start valve. This valve sprays extra fuel when your engine is cold. It is controlled by a thermo-time switch located on the head at the coolant outlet. First thing you could do is to make sure none of the connections are corroded.
Good luck!
Old 10-29-2005, 08:26 PM
sullygullly sullygullly is offline
Mein Auto: 01 525it & 87 325is
Could just be a dirty fuel filter, preventing the fuel pump to pressurize the system properly.
I good way to find out if that is the problem, is to do this:
Turn the key to the on position for a few seconds(but don't crank the engine). This engages the fuel pump, allowing the system to pressurize. Do this 3 or 4 times, then start the car.
If the car starts up no problem and stays idling, then go out and buy a new fuel filter, cuz thats your problem.
Similar Threads
Engine stumble / cough on cold start up TurnAround X5 E53 (1999 - 2006) 4 11-30-2012 10:57 AM
Start up Problems, I need help russellblundell E34 (1989 - 1995) 0 05-21-2005 06:51 AM
325 Car Start Problems kdawg E46 (1999 - 2006) 6 04-29-2005 04:30 AM
Cold Start Injector on 318i Slider Do-It-Yourself H.Q. 0 02-20-2004 05:39 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
