E34 (1989 - 1995)
Old 11-01-2005, 06:15 AM
HumanRoughDraft HumanRoughDraft is offline
Mein Auto: 93 325i & 95 525it
Reverse Light Sw location E34 (Auto Tranns) ('95 525i Wagon)
Anyone know where this is on the automatic transmission? My backup white lights don't work & I failed the Massachusetts Safety Inspection. I took off the shifter T knob and the wood plate and cannot find it there. Someone told me it was on the side of the tranny under the car on passenger side. I have the car on jacks now but still cannot find it.
The Fuse (F12) is has power to it. The wires in the trunk lid have 12vdc to it when reverse gear is engaged and 0vdc when taked out of reverse, yet they won't light up. This confused me. I took the bulbs out and tested them - they are ok. Back to the wireing - If they have 12v why won't they light up? Could it be that a digital volt meter (being sensitive) "senses" a trace of 12vdc running to it via a faulty switch (which I cannot find) but doesn't have enough AMPS to light it?
Any help would be appreciated - thanks
Old 11-10-2005, 01:29 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
http://www.bimmer.info/forum/forumdisplay.php?f=10
post it there...
BUT, if you have 12 volt at the back, maybe the problem is between the wire w/12v and the bulb holder?
if you get 0v when in park and 12v when in rev., it soiunds all ok... check bulb area, socket...??
Similar Threads
what are the recalls on 95 e36?? nads12345 E36 (1991 - 1999) 28 11-27-2013 12:10 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 03:59 PM
Any 530i Engine Recalls? DANABANA 5 Series 3 01-22-2004 08:07 PM
