2011 328xi sport wheel tire size? - Bimmerfest - BMW Forums
Old 12-06-2017, 07:21 AM
crzrbmw crzrbmw is offline
Mein Auto: 01' 330i
Looking at a 2011 328xi I found online that states it has the sport package so I'm guessing it has staggered wheels. Do I need to run different sized tires front and rear or can I run 225/45-17's front and rear?
Old 12-06-2017, 07:40 AM
jat335i jat335i is offline
Mein Auto: 2010 335i
For that model year 2011 328xi Sedan/Wagon (No coupe), there is a Sport Package and a Sport Package with staggered tires. Since it only says 'Sport Package', then they are not staggered tires.
You would need to check the VIN# using a BMW decoder https://www.bmwvin.com/ to verify if has the Sport Package or the Sport Package with staggered tires.
JT
2010 BMW 335i
Monaco Blue Metallic
Premium+Sport Package
Auto/STEPTRONIC
COBB Stage 2, K&N, BMW Performance Exhaust
2005 Mustang GT
Redfire Metallic
5-spd
Ford Racing silver Bullitt wheels
Ford Racing Axle-back GTAs
Diablosport Predator
K&N CAI
http://www.cardomain.com/ride/2046852
1997 Toyota Corolla
http://www.cardomain.com/ride/3237714
1983 Mercedes Benz 380SL Roadster
Old 12-06-2017, 06:56 PM
Mein Auto: 01' 330i
Thanks. The only thing it mentions about wheels is S2KUA BMW LA wheel, V-spoke 285 so I'm guessing they're not staggered wheels and tires.
Old 12-06-2017, 11:32 PM
STR8-6IX STR8-6IX is offline
Mein Auto: 2011 535i, 2009 328i
those are some beautiful wheels, not going to lie. I reccomend going 235/45r17 all around. get the michellin pilot sport 4S
Old 12-07-2017, 09:22 AM
floydarogers's Avatar
Pedant and Curmudgeon
You can run the same size all round. The rears may look strange - if staggared the rear wheels will be (typically) a bit wider so the 225 will be stretched on them.
The 235/35 size that someone recommended is too small. Let tirerack.com select a wider size (if you want wider than 225) as it will get the profile correct.
Old 12-07-2017, 10:40 AM
my mistake, I meant 235/45/17 I will correct that now.
225/235 is the optimal tire width or an 8" rim. you really do not want to go past 245 in this case, it will "balloon" over the rim.
