ABC of Torque angle - what does it mean? - Bimmerfest - BMW Forums
Old 12-06-2017, 03:53 PM
scorleo scorleo is offline
Mein Auto: 328i
I get the first part i.e. 8 NM or 6 lb/ft, what's the second specification and how does one apply?
Torque specifications:
M8x26 - 8Nm + 90
M8x92 - 8Nm + 180
M8x112 - 8Nm + 180
The above specification is for oil sump (aka pan) bolts on N51.
Old 12-06-2017, 03:55 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: 2012 Feb 11 X5 35d (E70)
Torque to the indicted torque limit then the angle further to stretch the screw to maximum clamping force.
Note that Torque To Yield screws have yielded and are close to breaking and will not be properly reused again.
I am responsible for what I write, not for your understanding of it.
Old 12-06-2017, 04:15 PM
Mein Auto: 328i
Thanks Doug! I get it
Old 12-06-2017, 06:34 PM
Mein Auto: 328i
I thought I got it first but I don't think I processed it correctly Once it's torque to the specs using torque wrench then am I using higher torque/regular wrench to meet angle spec?
Old 12-06-2017, 06:46 PM
insightbrewery insightbrewery is offline
short-throw dipstick
Mein Auto: 2005 545i
Correct. Use the proper torque wrench to get it to the initial torque value, then use a regular ratchet/wrench to turn it the additional angle (so, 180 degrees = 1/2 turn), don't worry about torque for that. Go slowly of course so you don't snap a bolt or something.
If you really want to be anal, you can get torque angle gauges.
Old 12-07-2017, 07:10 PM
Mein Auto: 328i
Thank you! I thought I wouldn't need torque angle gauge as you suggested but damn, the 26 mm length is supposed to be 60 degrees and not 90 as FCP Euro suggested on their site. I'm glad I cross checked Bentley and newTis, so I do need torque angle gauge because 60 is bit tricky compared to 90 and 180. Now I need to see if I can find in any of the local stores in No VA...
Old 12-08-2017, 07:42 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
I think (in my opinion) you are reading too much into it.
I believe the intention of the additional angle is to make sure you tighten bolts evenly following the pattern that is provided in bentley or manual of your choice. So after the 8NM torque is followed for all bolts, they are tightened further to make sure preload is applied gradually and evenly. The problem is the bolts are now static and static friction is larger than dynamic, so that's why you have angle and not torque to overcome the initial static friction. Honestly 90 is quarter turn and 180 is half turn, you are ok approximating it, wouldn't worry about a few degrees off. 60 is just a nudge, smaller than quarter turn - done.
2011 328i X-Drive Sedan N51 AT; Black / Black.
Premium, Value, Hi-Fi stereo, etc.
Old 12-08-2017, 07:56 AM
Mein Auto: 328i
Thanks Watchme! The problem is I'm OCD and by degree an engineer so that's the key issue .
Advance Auotparts is just next door and they have this gauge, I plan to pick it up this morning.
Old 12-08-2017, 11:13 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Dead wrong. As Doug stated earlier, the purpose of a jointing-torque-plus-angle specification is to stretch the bolt by a substantial amount, typically almost to the point of breaking, to develop maximum clamping force.
Normally, as you tighten a fastener the torque required to turn it steadily increases, because the bolt material is stretching slightly and applying more force to the threads (that stretch is what creates clamping force, not friction per se). Tighten it further (past the yield point of the material, hence the term torque-to-yield) and the torque required to continue tightening it will actually decrease, as the bolt material begins to take on a permanent stretch. That is why an angle specification must be used--the torque ceases to be a reliable measure of the clamping force being applied to the joint.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 12-08-2017, 11:51 AM
Agreed completely, don't see how I am "dead wrong" though. There are multiple forces being engaged while tightening, my argument that torque is no longer accurate still holds as you pointed out. Did not know about the yield range of material being weaker than during its elastic elongation... thanks learned something new. I do believe the angle is also of purpose that you tighten all fasteners to torque spec, then do them all again for the additional angle turn to get them into yield range as you said.
