E90/E91/E92/E93 (2006 - 2013)
Slight hesitation after cold start
Has anyone noticed in their car a slight hesitation when starting the car in the morning for the first time? I've been noticing it more and more the past couple of weeks. At first it was ever so slight, now its very noticeable.
What I usually do. Start the car - wait till everything stops beeping, etc Push on the brake, move the car into drive and pull out. In my garage there is no need to use the gas to pull out so the car pulls out off of idle. While moving out it will hesitate, until the engine recovers, then lunge forward. Sometimes it does this twice. To avoid it, all I have to do is tap the accelerator for a few seconds before dropping the car into drive. Got my car into the dealer today to check it out. They where able to experience the same phenomon. They just called me saying a SW upgrade may fix it. Who knows, will find out tomorrow. Anyone else see this? It's a 330i Sport, Cold Weather, Premium. 8,000 miles on the car this week. I've ran Chevron premium for every fill up. |
Software upgrade can fix this, software update can fix that....BS...they say it always when they have no idea how to fix the problem. Tell them that you have pain in you knee and I am sure the will say "...software update can may fix that".
What I'd recommend you to do is not to try to pull out of the garage as soon as everything stops beeping. Give a car five minutes to worm up. This is what I usually do. Lately it started to shake a little bit when I first start it in the morning. So I give it about 5 minutes or so of a worm up time. I am not a mechanic, it just my opinion. Let me ask you this question: when you already driving the car during the day, and you stopped somewhere for 30 minutes for instance. And them get back to you car and start it after it was worm for most of the day - do you experience the same behavior? If so then you may indeed have a problem. If not - I doubt very much that software update has anything to do with it. Again I am not a mechanic. mike |
FWIW, I had a similar problem last winter with my 2003 X5 - hesitation on first start, much worse when cold.
I'd back out of the garage (no gas needed, like the first poster), down the driveway and then shift into D. I'd step on the gas, and nothing would happen, for about as long as it would take for me to look down to make sure I was definitely in D and not N. Then everything would be fine and I'd drive off, no problems the rest of the day. Warming up the car didn't help. Shifting c-a-r-e-f-u-l-l-y from R to D didn't matter. A software fix is what fixed it. Something about a valve staying open, letting part of the system depressurize, which was exaggerated when the temperature dropped. That was last year, right around Christmas. No trouble during the entire Jan-April cold weather, and no reoccurence during the first cold here in October-November either.
![]() 2006 325xiT | Alpine White | Black Leather |
2006 325xi, 6-speed, E-Red, ZSP, Xenon, Bluetooth/Assist, Comfort Access, Active Cruise, NAV, Sat Prep |
When my car is on a cold start, I wait until the RPMs drop to normal idle before I start driving.
http://www.cardomain.com/ride/2077713 |
Any idea why E90 doesn't have engine temp guage like most cars GOD makes ?
Arctic Metalic | Beige Leather | Premium | Winter | Xenon | Navigation | Steptronic 2006 325i (current) 2002 Toyota Camry (2001-2005) 1980 Peugeot 505 (1995-2001) |
I have the same issue with my pre-September 330i with auto transmission. I took the car into the dealership two days ago for the same problem you described. The service dept updated the software on the car and said the problem should be fixed. I picked up the car last night.
This morning I was interested to see if the problem was fixed and started to back out of the garage... The car stumbled and caught and stumbled again, then ran fine once I put the car in drive and pulled away. Needless to say the software update did not fix the problem. I'm interested in the comment that Commander Crash made about a transmission replacement fixing the problem. I've noticed that every now and then my transmission makes a kind of metallic slapping noise when shifting the car between park, reverse, and drive. Do you think this could be related to the cold start hesitation? |
Hmmm
“The E90 is kind of special in that the magnesium engine with the new thermal management (heated thermostat and electric waterpump - electronically controlled) has a far wider range of operating temperature. To increase fuel efficiency and power output, the operating water temperature is intentionally regulated by the ECU to temperatures between 75deg C and 125 deg C depending on driving conditions. Slow driving in traffic with little demand for power will make the ECU run the water hot to improve fuel efficiency, high power demand will have the ECU regulate the water temp to low values to improve power output. Classic thermal management (belt driven pump and simple thermostat) would regulate to remps between 90 deg C and 120 deg C).” I also frequent e90post.com. There is a guy over there, e90fleet, that really knows the e90. There are several threads over there about the lack of the gauge. His response is always similar to my original post. I have never seen this explanation disputed. Do you have other information? |
Thanks rkwjr. I read e90post every know and then too, I like bimmerfest more though
but that was very informative
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rattling Noise Cold Start! | MC | E46 (1999 - 2006) | 46 | 04-22-2013 06:16 PM |
| Engine stumble / cough on cold start up | TurnAround | X5 E53 (1999 - 2006) | 4 | 11-30-2012 10:57 AM |
| y wont it start cold? | REDLINEREP | E30 (1982 - 1993) | 2 | 09-23-2005 08:16 PM |
| Ticking noises on cold start | CMOS | 3 Series / 4 Series | 6 | 05-23-2004 09:48 AM |
| cold blooded chick (slight work warning) | HW | Off-Topic | 6 | 11-25-2003 01:39 PM |
