E36 M3 (1995-1999)
The ABS & ASC lights have turned on and will not shut off. the control button for the ASC does not respond. i dont know what happened. what could it be?
when that happened to me - it was first intermittant, then later became permanent. It was a faulty wheel sensor.
It could also be a relay - you should be so lucky.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression |
ligth on
I just changed the same part that you will need it goes on the brake master cylinder the part # is 34333 1 182 594 that will be the part you need to order from the dealer , the c clip is a pain to get out it holds the sensor you will need some long plyers to acces the c clip. good luck, let me know how it goes.
abs controller
it is most likely the abs controller. alot of them will through a right rear speed sensor code and it is a short in the controller it self i've replaced 6 that I know of
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ASC, ABS Indicator Light Stays on. | yema0003 | E39 (1997 - 2003) | 27 | Today 07:06 AM |
| Option code list | Terry Kennedy | General BMW | 16 | 05-14-2006 03:59 PM |
| BMW ConnectedDrive: | ChrisTO | General BMW | 12 | 11-08-2005 06:41 AM |
| ABS Light | hdd3md | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 2 | 05-10-2003 10:05 PM |
