Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 09-10-2002, 05:18 PM
ouzlizard ouzlizard is offline
Mein Auto: 2002 330i
I replaced the front license plate holder and now have two holes in my bumper
I replaced the front license plate holder with the replacement rubber strip and now I have two holes in my bumper from where the front license plate holder was affixed via screws to the bumper at the bottom of the holder.
Anyone have any experience in this regard? Specifically with covering up or repairing the holes.
If I had known that the front license plate had been secured the way it was I would not have bothered to buy the replacement strip.
In case anyone is curious, the replacement rubber strip is part number 51 11 7 030 611.
At first I thought maybe that the dealer was responsible and then I went back to the pictures from the Euro delivery and the folks in Germany are the culprits for the overdone fastening job on the front license plate holder.
I suppose that my other option might be to put the front license plate holder back on and then try to put as a plain a vanity plate on the front as possible.
I live in Florida so there is no requirement for a front plate.
ouzlizard
2005 325iT, PP, Step, Jet Black, Sand Leather, Xenon Headlights
Old 09-10-2002, 05:52 PM
eugeneDC/TX eugeneDC/TX is offline
sometimes i wish for an x
Mein Auto: 2001 325i
i thought only the coupes needed screw holes on the bumper. the sedan plate bumper part has screw holes. at any rate, i know you can purchase little plastic tops to put into the holes. i doubt they make bmw specific plugs, but they're so small a little touchup paint would do the trick.
Old 09-10-2002, 08:48 PM
GSR13 GSR13 is offline
Revelation 10:7
Mein Auto: 2003 330i
Only the coupes do need the holes. The problem is, when the dealer puts the front plate on, which is typically a dealership plate, they drill through the plastic strip into the bumper.
Personally, ouzlizard, I would take it to the dealer. I would try my best to make them repair it. There is no reason for them to do that and it certainly is not the first time I have heard of it.
As for fault, I believe it is the dealers fault. I have seen pictures of cars at dealers that have not gone through PDI and those cars have no Center Strip at all. They have no tag on the front. The dealer installs the strip of their choice.
Regardless of who did it, it was not you. This is one of those things that I despise. It is bad enough they use your car for free advertisement, but the fact that they drill through your bumper is ridiculous.
Old 09-11-2002, 05:42 AM
Thanks for the input GSR13.
I will try to go through the dealer but it was a Euro delivery and that license plate holder was on there when I picked it up in Germany. It was holding the German license plate. I think the guys at the factory fastened it on there good and tight as per the instructions.
I think that I will also follow EugeneDC's advice and try to find little plastic plugs and see how that looks.
ouzlizard
Old 09-13-2002, 01:53 PM
the only ppl i know with the plugs are ppl who have like hondas who had the dealers screw in the plates. the plugs arent THAT noticeable, but it's a cheap stopgap until you get the dealer to fix it. and if you cant get the dealer to do it and dont want to buy a new bumper, it's definately better than holes in the bumper.... but with touchup paint, it should be relatively hidden
Old 09-13-2002, 11:51 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
There is an aftermarket company that makes bumper plugs for Porsches, etc (in their standard colors). I'm at home, but when I get to my machine I'll look for the link (I may get them one day). I think they're about $20 a pair.
Old 09-14-2002, 06:29 AM
ObD ObD is offline
Mein Auto: '08 535 6mt
bumperplugs.com
Old 09-14-2002, 08:22 PM
into things retro
Originally posted by ObD
bumperplugs.com
Old 09-24-2002, 09:25 AM
325ci.com 325ci.com is offline
Send a message via AIM to 325ci.com
Mein Auto: 2001 BMW 325Ci
yeah, my front bumper was drilled through for plates, and i did my euro delivery as well.
i just run around right now with the holes, but you can simply plug it with some window-weld and then put some touch up paint over it.
Mike Choi | Manhattan Island, NYC, NY, USA
'07 Lotus Exige S & '86 Toyota MR2 & '92 Toyota Celica AllTrac Turbo & '01 BMW 325Ci
Old 09-24-2002, 09:30 AM
into things retro
The one advantage . . .
I can think of for the bumper plugs is for example around here, there are some cities that STRICTLY enforce the front license plate (Raffi and Stuka wouldn't know anything about that now, would they?) so it's an easy way to place the front license holder back on if going to one of those places.
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 09-24-2002, 11:06 AM
Raffi's Avatar
Raffi Raffi is offline
Hi
Mein Auto: Frankenstein monster
Re: The one advantage . . .
Um, are you talking about West L.A., West Hollywood and vicinity? That's when Butyl tape comes in handy to hold the license plate holder!
'01 330ci
