E34 (1989 - 1995)
Old 11-14-2005, 04:34 PM
old5 old5 is offline
Mein Auto: 91 525I
Question Oil pan gasket replacement??
I need to replace th gasket on a 91 525i. I see a couple people have done it. But I can't find solid detailed info, can any give me detailed info + pics would even be better?
Any help would be appreciated!
Old 11-14-2005, 08:26 PM
bmw330pp's Avatar
bmw330pp bmw330pp is offline
bmw330pp
Mein Auto: 04 330Ci ZHP, 06 CBR600RR
I just did it about a month ago on the exact year and car, and its a bitch if you don't have a lift. I spent close to a week on it, at about 2 hours a day. Unfortunately I didn't take pictures but can most likely talk you through any complications. Try and do a search on what I wrote.
2004 330ci, Silver ZHP, Xenons, Sunroof
Old 11-15-2005, 07:34 PM
Mein Auto: 91 525I
Thanks I'll do the search, of course I don't have a lift. But what is the toughest part of that job??
Appreciate the reply
Old 11-15-2005, 09:35 PM
bmw330pp's Avatar
bmw330pp
Removing the cross-brace, and all the suspension and steering components attached to it. You must take the front tires off before doing this. After you get the brace out of the way everything is fairly simple from there. There are a few tight bolts, and 2 secret/hidden ones towards the back of the pan. You will need a torx bolt set to remove a few bolts towards the back, which go into the pan from the tranny. Once you get the pan to drop a bit, you need to remove the two bolts holding the oil pump pick-up inside the pan. You also need to take off the bolt holding the timing chain on.
Similar Threads
DIY - 528i OIL Change (E39) 6 cyl GOKOOLJAPAN 5 Series DIY 56 12-18-2009 12:08 PM
M50 Oil Pan Changeout Question geebeemer E34 (1989 - 1995) 2 07-06-2005 07:58 AM
Qusetion about switching to synthetic oil... PeteG E36/7 Z3 (1996-2002) 13 10-20-2004 09:29 PM
White puff of smoke and possibly eating oil... jpipes E36/7 Z3 (1996-2002) 0 06-21-2004 03:46 PM
Good Article on Synthetic Oils GSR13 General BMW Questions 21 05-07-2003 02:17 PM
