Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 11-22-2005, 09:03 AM
jostalli jostalli is offline
Mein Auto: 2005 645CI
I-Drive says flat tire.
So does this mean I should take it in to BMW or should I just have a tire shop do it? I just checked the pressure and it's at 2psi.
Old 11-22-2005, 09:20 AM
Pilot_Guest Pilot_Guest is offline
Account closed at user's request.
Mein Auto: BMW
is it really flat?
isnt 2 pounds per square inch a bit low? i don't think i would drive it if it is that low, those tires are like $500 a piece.
Hint: push on the tire and see if it is soft and compare it to the other tires on the car, also look for sidewall bubble.
Old 11-22-2005, 09:24 AM
credit777's Avatar
credit777 credit777 is offline
Mein Auto: 750i
Dude....2psi means flaaaaaaaat. How far are you from a Discount Tire (they are great in my area - but may have to order the tire). Call first and make sure they have the tire.
Do you have the tire warranty?
[His] 2006 750i Sport - Jet Black, 21" wheels, premium sound, luxury seating, convenience, comfort access, Sirius (Jet)
[Hers] 2008 650i - Metallic Black, Sports, Prem Sound, HUD, HD Radio, Cold Weather, Sirius (Shiloh)
Moved on from:
2005 645Ci (Ava)
2004 545i (Chief)
2002 330i (Kira)
1998 528i (Slick)
1999 540i (Sly)
Old 11-22-2005, 09:40 AM
No, I don't have tire warranty. The tire looks slightly low but definitely doesn't look flat. The pressure gauge says 2psi. The car drives normal. I guess the run flats are working. It's the driver rear tire.
Old 11-22-2005, 10:10 AM
Mein Auto: BMW
are you sure thats 2 psi?, take another look and try another guage
Old 11-22-2005, 11:00 AM
SmoothCruise SmoothCruise is offline
Mein Auto: 645 Convertible
I take mine to the dealer, but I have tire warranty. You should be careful because even though the run flats do work, it still doesn't prevent rim damage. That has happened to me, so not only did the tire have to be replaced, but the rims too. And those rims aren't cheap.
Old 11-22-2005, 12:31 PM
grahambishop's Avatar
grahambishop grahambishop is offline
Graham
Mein Auto: 2004 645i Coupe
Exclamation
You get to drive 150 miles at a max of 50 mph, per the warning I just got yesterday. Took it in immediately...the tire pressure was 20 pounds. They pulled the nail out and patched it and I am rolling again for Twenty dollars. Two pounds is negligible and if you have driven very far or fast, I would strongly recommend that you buy a new tire. You should take it to a good tire shop and have it looked at. It isn't worth your life to risk a tire that may be "chancy" for lack of a better word. The tires are expensive, but cheaper than funerals. That's my .02
Old 11-22-2005, 01:46 PM
credit777's Avatar
Mein Auto: 750i
Your rim was covered, right? Hope so.
Moved on from:
2005 645Ci (Ava)
2004 545i (Chief)
2002 330i (Kira)
1998 528i (Slick)
1999 540i (Sly)
Old 11-22-2005, 02:10 PM
Yes, rims were covered with insurance, but the first time they were damaged, the insurance didn't cover it because it was 'my fault'. However subsequent damage to my rims were covered by insurance.
Old 11-22-2005, 03:44 PM
credit777's Avatar
Mein Auto: 750i
Usually I opt out for "tire" insurance - but I went ahead and got it this time since the run-flats can be difficult to repair. I'll start looking for nails in about 18K miles .
Moved on from:
2005 645Ci (Ava)
2004 545i (Chief)
2002 330i (Kira)
1998 528i (Slick)
1999 540i (Sly)
Old 11-22-2005, 04:19 PM
Well, gents it was the ol' nail in the tire. Tire place down the street patched it up for $30.
Old 11-22-2005, 05:05 PM
What do you do to patch it up? Please enlighten me. I thought you had to pretty much get rid of your tire? Is patching up safe? Effective (meaning, will you have to repatch later?)
Old 11-22-2005, 05:11 PM
philippek philippek is offline
Proud S ponsor
Mein Auto: Z4 M Cpe, Miata, X6 50i
A runflat will never look flat.
Old 11-22-2005, 05:21 PM
They plugged the hole. I asked if that was the "best idea" and they assured me they perform this same procedure on run flats with great success. The service manager even whizzed through the I-Drive to reset the pressure monitor in a half second.
Old 11-22-2005, 06:11 PM
Malibubimmer Malibubimmer is offline
Officially Welcomed to The 'Fest!
Mein Auto:
Unless you are certain how much (or little, actually) damage your tire has received it is a bad idea simply to patch it and think everything is normal. Maybe it is, maybe it isn't. The whole point of a run flat is to maintain its shape for 50 to 150 miles, depending on load and speed. It does this by sacrificing its integrity over a lengthy period of time. So, if you caught the flat the instant it occurred, and never drove on the tire with 2 ppsi, well then you're okay. If you drove on the tire for 20 to 30 miles, its integrity is compromised and as it continues to bear weight it will deteriorate and eventually fail completely.
So, before patching the tire the tire guy should have been asking you some questions. Did he? Did he carefully inspect the interior of the tire and check its flexion? What did he find?
Whatever happened, good luck, but I think you may need to see a run flat specialist.
Old 11-22-2005, 06:15 PM
E2R41L's Avatar
E2R41L E2R41L is offline
Mein Auto: 2006 Jet Black BMW 325i
2 psi = flat = take care of the problem immediately.... run flats are supposed to be rated for up to 50 miles (with the factor of safety), so it may look ok, but its flat. I'd say go to the dealer.
Jet Black 2006 325i
Tan Interior
Navigation
Premium and Cold Package
Old 11-22-2005, 08:33 PM
credit777's Avatar
Mein Auto: 750i
Who is "they" as in "they plugged the hole"? If its a dedicated tire shop I'm sure you're ok. I once punctured a very new 19" low profile tire and took to Discount Tire (luuuuv those guys) to get it patched. They wouldn't do it because the nail ruined the tire. I complained (and cried)...but they wouldn't budge. I was told that by law they can't patch a tire if they believe the integrety is compromised.
Now if it was some dude at a garage....
Moved on from:
2005 645Ci (Ava)
2004 545i (Chief)
2002 330i (Kira)
1998 528i (Slick)
1999 540i (Sly)
Old 11-23-2005, 09:10 AM
It was Goodyear Tire on Ventura in Encino.
Old 11-23-2005, 10:42 AM
Mein Auto:
Good to know when the tire blows - they will not be "judgment proof."
Old 11-23-2005, 11:32 AM
Blinky330XI's Avatar
Blinky330XI Blinky330XI is offline
Mein Auto: 330XI
WOW! I get my tires "patched" for $10 all the time!
Similar Threads
Tire Pressure Light Blinks - no flat??? z3scot E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 8 09-10-2005 03:47 AM
Flat Tire Question 330soon2b E46 (1999 - 2006) 2 07-09-2005 10:59 AM
745I Flat Tire (help) Billy_Boy 7 Series / 8 Series 2 08-04-2004 10:14 AM
Automakers jumping on the rear-wheel drive train Pvt. Joker Off-Topic 3 01-07-2004 10:09 AM
Flat tire - could it be my excuse? Michael330 General BMW 13 02-27-2003 05:58 PM
