Old 11-23-2005, 01:40 PM
bavarian19's Avatar
bavarian19 bavarian19 is offline
stop staring at me swan
Mein Auto: E90 335
Window Trim Swap/Replacement DIY
Ok. I have been getting a few PM's about how I did the chrome trim swap, and here is the DIY. Sorry no pictures... I did it all without taking the time out to snap pics...
Total Time about 1.5 hrs
Front Kidney Grill - Really easy. Follow the DIY from e90post: http://www.e90post.com/forums/showth...t=grill+chrome
Just pull, and it pops out. Snap the new grill into place. If you have serious troubles with this, go pay someone (preferrably me) to do the rest of your trim swap
Upper Window Trim - This trim is rather easy to swap out. Open the two doors on that side. Starting in the middle, put your fingers in the small gap on the upper side of the trim, and pull back. This trim is held into place by clips, and should be rather easy to pull back. Once you have the middle started, work your way from the middle to the back, and when thats all finished, work up to the front. The upper trim should not take you long to do.
To snap in the new trim, you might need to take some clips off of the old trim being as they might have popped off with the trim. Put them back in the respective holes they came in.
Now you should be ready to pop the new trim into place. Start by pushing the trim into place in the middle again. Once the trim is clipped in place, make sure the trim will line up with the curvatures of the window lines. Once it all lines up, work your way to the rear of the car snapping it into place. Then finish up with the front part of the trim.
Lower Window Sill Trim - This is the complicated part. Word from the wise... If you are trying to do a trim swap with a 330 owner (taking their chrome trim), you can not reuse this trim. In the process of taking this trim off, it will bend (it is made of metal). When you straighten it out, it will have small bubbles in it, and it wont look good. It will look like someone took a ballpine (sp) hammer and had a few swings at your trim. If you are going to chrome trim, you will have to buy these parts in some way or form. When I did my trim swap with James from bimmerworld, we did not know this, and James was curteous enough to buy me the trim. The black trim from the 325 can be reusable if it is taken off properly. Its made of plastic.
So how do we do this? Here we go... Back windows... Open your back door and roll down your windows. On the edge of the trim closest to the back of the car, you will notice that the trim conforms to a small groove inside the door. You will need to take a small regular headed screwdriver, and pry upwards popping that part of the trim out. Once that edge is up, pull from both sides of the trim (inside edge of the trim from inside the window and the outside edge) working your way to the front of the car. There are two pieces to each of these window sill trim pieces. The plastic trim (or metal if its a 330) and a rubber sheathing that is used to attach the trim to the window sill)...
So that is how to get the rears out. To get the fronts out is much more complicated. For this process, you need to remove your side mirrors. To remove the mirrors you have to do three things.
1 - You need to remove the door panel. Starting from the vertical part of the door trim, pull hard on the door panel. You will need a good amount of force to pull this off. Pull it back so you can access the black plastic lining that runs around the inside upper part of the door. You do not need to completely remove this panel, but it needs to come about halfway off for you to get what you need.
2 - Remove the inside plastic trim that runs on the upper part of the door. This is simple to remove if you have removed the door panel correctlty. Just pull it off of the door. It will still hang in place due to some wiring of the side speaker. This will give you access to the 3 torx screws that hold the mirror in place.
3 - Remove the mirror. Using a torx screwdriver, remove the three screws holding the mirror in place. Make sure you are holding the mirror when you unscrew the last one. Dont want your mirror to fall and scratch your car. You will need a second person to hold this while you are doing the trim swap.
Once these three steps are complete, you can remove the trim smiliarly to the rear window trim.
Putting the new trim in. If you notice, the rubber part of the trim has a single channel that needs to match up with the 'wall' inside the door. There is also a small plastic clip that sits on the rear side of the trim. You need to start in the rear with installing the trim. Slide the rear plastic clip over the edge of the door (you will need to be pushing down on the trim a little bit to get it into place). Slowly push the trim down into place. The rest of it should slide right in if you have lined everything up in the rear. This goes for all 4 window sill trim pieces.
Putting your front doors back together. Backtrace your steps to remove your mirrors. Put your mirror back on. WHen you put the black plastic piece back in place, make sure it covers the weather stripping when your putting it back on... This is challenging (somewhat). Snap your door panel back in place.
Last step. Enjoy your new trim. If you have followed my directions, crack open a beer and celebrate the fact that you made sense of this long DIY.
Thats it...
Old 11-23-2005, 01:45 PM
bavarian19's Avatar
Mein Auto: E90 335
Please read all of this before sending me a PM. Its pretty detailed, and I dont know what else I can tell you...
Enjoy it...
Old 11-23-2005, 02:08 PM
Boile Boile is offline
Mein Auto: .
Perhaps add a few pictures of the final result...
Old 11-23-2005, 02:13 PM
bavarian19's Avatar
Mein Auto: E90 335
From when I had my 162's put on... notice the wonderful chrome trim
http://www.bimmerfest.com/forums/sho...63&postcount=8
Old 11-23-2005, 02:20 PM
bavarian19's Avatar
Mein Auto: E90 335
Sorry for the pathetic add ons... but figured it might help...
Old 11-24-2005, 06:27 AM
ase2dais's Avatar
ase2dais ase2dais is offline
Arrive Alive w/ my e92 M3
Mein Auto: E90SG E92M3SG
Hey ! Bavarian! Someone Vandalized Your Car With Spray Paint!
Old 12-13-2005, 01:53 PM
bavarian19's Avatar
Mein Auto: E90 335
Atleast they did it in Christmas colors!!!
(holy thread ressurrection )
Old 02-15-2006, 09:55 AM
shiraishis's Avatar
shiraishis shiraishis is offline
S
Mein Auto: 2006 325I
Cool post anyone know where I can buy some trim for my E90 so I don't get gang raped by my dealer
2006 BMW 325i, Artic Silver, Black & Silver interior, Chrome grill and exaust, Sports, Winter, and Premium packages with Navigation
Old 04-24-2006, 08:29 PM
dh504 dh504 is offline
Mein Auto: -
hey where did u get/buy the window trim from?
Old 04-25-2006, 08:01 AM
KL2DC KL2DC is offline
Mein Auto: e90 325i / EJ6 Civic
Bavarian19 was lucky enough to locate someone with a 330i who wanted to trade him for his black trims...if you ask him, he would suggest the same i.e. to locate a candidate to swap trims. Keep in mind removing the chrome trim could sometimes result in slight damage (as stated in his comprehensive DIY guide). I believe OEM parts from the dealer adds up to about 400-600 bucks.
325i : Sparkling Graphite : Black : Poplar : Step : PDC : Xenons : Sirius Factory Install ...
Old 06-30-2006, 05:44 AM
06BMW325xi 06BMW325xi is offline
Mein Auto: 06 BMW 325xi
Trade my 06 325xi black window trim for chrome.
I WANT CHROME WINDOW TRIM, AND I DONT KNOW HOW TO GET IT!!! HELP MEEE lol
Old 06-30-2006, 07:45 AM
These are the part numbers, all pieces should be available at your dealership.
Chrome Exhaust Tip-
Part # 82-12-0-398-334 $35.00
Chrome Upper Window Trim-
(L) 51-13-7-121-235 $157.00
(R) 51-13-7-121-236 $157.00
Chrome Lower Window Trim (Front)-
(L) 51-33-7-119-981 $53.00
(R) 51-33-7-119-982 $53.00
Chrome Lower Window Trim (Rear)-
(L) 51-35-7-119-215 $53.00
(R) 51-35-7-119-216 $53.00
Chrome Kidney Grills:
- 51-13-7-120-009 Left
- 51-13-7-120-010 Right
For installation either follow bavarian19's DIY or bodyshop
Similar Threads
Changing chrome window trim to shadowline? C-Bear 3 Series & 4 Series 2 01-02-2004 10:19 PM
Anyone want to trade their ext chrome window trim for my black shadow trim? jaisonline Classifieds 1 09-24-2003 08:17 PM
POLL-change chrome window trim or not? drpahjee 3 Series & 4 Series 11 04-22-2003 08:19 AM
TRADE: E46 M3 black window trim for my chrome... sar0 Classifieds 0 04-17-2003 08:20 PM
Black window trim on 330i? Plaz 3 Series & 4 Series 4 01-08-2002 05:54 PM
