Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-01-2005, 12:38 PM
lil' poppa's Avatar
lil' poppa lil' poppa is offline
howdy
Mein Auto: 2004 330i
Fog lamp cover replacement Q
Cracked another lamp cover (i.e. the lens). My question is specifically about the M-tech front bumper on a performance package 330i.
The question: wondering if the act of getting the fog lamp housing out of the front end is a simple "snap out" procedure. Actually, I've gotten the housing off the bumper, and the more specific question is whether there is any nuance involved in snapping it back in. I put the housing back into place, but it feels a little loose. Am I imagning things, or is there a trick to getting the snaps to take?
I didn't see an exact answer on my330i.com or m3.madrussian.net, so I thought I'd check here as well. Too bad Mr. Boschforeignltd is out of business, otherwise I'd go straight to him.
Thanks for any help.
LP
Similar Threads
FS: 04/05 X5 Headlamp and Fog Lamp Clear Guard kit JaySpec7 Exterior 0 09-30-2005 03:00 PM
Missing oil drain cover...? Wingboot 3 Series & 4 Series 12 09-03-2004 02:19 PM
FS: E46 Sedan Cal Car cover jw Classifieds 5 08-25-2004 08:13 AM
Car Cover question?? Closer General BMW Questions 3 08-26-2002 09:59 PM
euro rear fog lamp retrofit confirmed to NOT work.... 31st330i 3 Series & 4 Series 1 02-07-2002 07:02 AM
