what is the best Chip for my 97 coupe M3 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 12-03-2005, 09:35 AM
E36 ///M3 E36 ///M3 is offline
Mein Auto: '97 E36 M3
I just got 97 m3 coupe now I need to know what is the best Chip to put in this Baby ...Shark injectors??
Old 12-04-2005, 11:47 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Search
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-07-2005, 07:54 AM
PHROZENM3 PHROZENM3 is offline
AA Tuning Consultant
Send a message via AIM to PHROZENM3
Mein Auto: E36 M3
Check out what AA has for your car.
http://www.aatuning.com/software/obd-ii.cfm
[MY RIDE: E36 1998 M3. AA Rotrex Supercharger. Ground Control Coilover Suspension Kit. AA Track Pipe and Gen 3 Exhaust. UUC Clutch and Lightweight Flywheel.
pcalloway@activeautowerke.com hit me up if u have any questions
Old 12-07-2005, 05:31 PM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
If you have nothing aka stock. Its best not to "chip' the car, until you have atleast add some mod's parts.
Once you get all your mod on your, then get the chip tune for your car via AA, Jim C, Nick G, etc..
Old 12-07-2005, 06:27 PM
milimonster milimonster is offline
Mein Auto: silver 99m3
Chip
What necessary modifications do you have in mind Duck? I too have a stock E36 i would like to chip.
Old 12-07-2005, 07:06 PM
Mein Auto: E36's
I recommend this item to BEFORE you get your car "chip"
1. M50/S50 manifold upgrade will net you around 15hp
2. Stromung or AA exhaust or any GOOD exhaust
3. AIT (airintake)
4. Change your Diff to 3.32LSD or 3.23LSD from 3.15LSD (manual)
5. Shrick cams (I hope, I spelled it right) pricey, but will net you some good HP.
Once you done 1-3 then get your car "chipped" by AA or Nickg or other tuners. Step four and five is option, but will help you open a new assh*** for anyone that wants to race you
Old 12-08-2005, 11:06 PM
Pinecone's Avatar
M Mad
Although a Conforti chip ina stock car will allow a higher redline that will actually allow you to get to the proper RPM to shift for maximum acceleration.
And BTW a 97 manual car should already HAVE a 3.23 rear.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-09-2005, 06:06 AM
SoloII///M SoloII///M is offline
Poseur
Mein Auto: Too many
I think most engine builders will agree it's not a particularly good idea to rev the S52 motors much higher than they already do. S50 ('95 M3) is a different story altogether.
Old 12-11-2005, 03:06 AM
Pinecone's Avatar
M Mad
I think the Conforti goes to 7K which isn't that much higher, but does allow proper shift points. Me thinks that BMW picked the tranny ratios for the Euro motor, not the US one.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-14-2005, 11:07 AM
zydeone zydeone is offline
Mein Auto: 97 E36 M3
FYI: the JimConforti shark injector and air intake (itg foam) are top of the line after years of trials and testing he perfected a balanced software upgrade. Goto turner motorsport. Others like bavauto offer the same exact chip with different packaging around $359.
The "chip" opens rev limits, top speed and throttle response but its a subtle difference, your not installing a turbo or supercharger. Make sure you level out the intake and exhaust before you chip it because your changing the timing. read the directions carefully if your doing the upgrade, if you use a cheap battery charger you could screw your ECU up and end up with a undrivable car.
When your ready to step up to headers i'll see you on the streets.
'97 M3 black on black
Old 12-14-2005, 12:32 PM
Poseur
Mein Auto: Too many
Unless you're stepping up to some big-buck long-tube headers you'll lose more than you'll gain swapping out the factory manifolds.
Similar Threads
2003 M3 Coupe Loaded & Low Mileage cedwardbrice Cars - Private Party 2 01-23-2006 11:52 AM
Spartanburg newspaper quotes some of us about Z4 Coupe dwaynemosley E85 / E86 Z4 (2003-2008) 38 09-18-2005 09:25 AM
Fs: 1998 White M3 Coupe OrlandoM3 Classifieds 1 11-30-2003 05:09 PM
WTB: E36 M3 (95-99) front bumper/fenders (any E36 coupe fenders fit) joekannooks Classifieds 0 11-29-2003 10:53 AM
M3 or M Coupe toshweir27 General BMW Questions 12 02-22-2002 05:52 PM
