E34 (1989 - 1995)
Old 12-05-2005, 09:40 AM
moehjr moehjr is offline
Mein Auto: 94 530i
locating oil pan plug on 94 530i
I'm attempting my first oil change on a '94 530i but don't know where exactly the location of the oil pan plug. Once found what should I use to remove it (17mm wrench)?
I saw two holes close to each other at the bottom center area just past front wheels. One was a cover screw but wasn't sure what the other was for. I have my jack stands, lift, oil, filter, rags, and oil disposal pan.
I want to try changing the oil using this method first and then probably via the dip stick later. Any assistance you provide a first timer is appreciated.
Old 12-05-2005, 06:51 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
go here...
http://www.bimmer.info/forum/forumdisplay.php?f=10
http://www.bmwe34.net/
Similar Threads
what are the recalls on 95 e36?? nads12345 E36 (1991 - 1999) 25 11-15-2009 01:17 AM
Is my 4.8is a lemon??! ZenX5 X5 E53 (1999 - 2006) 68 09-15-2007 08:08 AM
94 530i radio died dbag E34 (1989 - 1995) 4 02-16-2007 12:04 PM
Lift your car? luciano136 E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 37 10-04-2005 09:24 AM
Any 530i Engine Recalls? DANABANA 5 Series 3 01-22-2004 08:07 PM
