E30 (1982 - 1993)
Old 12-18-2005, 04:14 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Cluster Tip: Left Turn Signal Flashes Outside but not in Cluster.
If your left turn signal doesn't flash inside, your main board in your cluster has cracked due to time and stress. You have two options at this point. 1. Replace the cluster (Duh). 2. Disassemble the custer and repair the main board.
If you choose to try and repair the main board you first need to evaluate your soldering skills. The board usually cracks where the screw at the top right(facing screws).Follow the lines that run from the light , one of them goes on the outside of the screw hole, this is the one that seems to be a problem. You need to look with a good light and mabey a magnifing glass for a break in the board. You will have to lightly scrape off the protctive coating to reveal the copper. The breaks are hard to see and you may want to go over this area with a liberal amount of solder anyway. Also spot some on the contacts where the bulb and multi-plug are. Be careful not to run two contacts together with the solder.
If this part is over your skill level you can still dis assemble the cluster (or not) and drop it off at your local TV/VCR/DVD repair shop and they can perform this service. (for usually a very small charge mabey 20 or so)
Old 12-18-2005, 06:30 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
I had that happen too. But mine was just a shot bulb in the left turn indicator.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 12-18-2005, 07:14 AM
On Top
Nice, you are 1 of the lucky 1's
Old 12-18-2005, 07:47 AM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 85 VW Quantum
this is why i am keeping my spare cluster. if something goes bad like this i can just swap them around with replacing the spedo part and i am good to go.
Old 12-18-2005, 07:52 AM
Rather Large Member
Wise decision I think
Similar Threads
turn signal acting up corgicoupe E36/7 Z3 (1996-2002) 8 09-26-2005 10:38 AM
Stuck Turn Signal OneR2TeeS E46 (1999 - 2006) 1 08-29-2005 05:13 PM
Pictures from Covered Bridge Tour Rufus330Ci Automotive / Photography 15 08-24-2002 08:04 AM
Drivers side turn signal bulb ObD 3 Series & 4 Series 0 08-03-2002 10:35 AM
Roof not open, sit belt sign on, and no turn signal FrancisK 3 Series & 4 Series 2 04-18-2002 08:54 AM
