Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 12-20-2005, 07:07 PM
jspit540i jspit540i is offline
Mein Auto: 540i
power steering fluid
how do you change the powering steering fluid and what kind should i use?
Old 12-20-2005, 07:44 PM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
There usually isn't a drain valve in the power steering resevoir, so you'll have to use a turkey baster or fluid extractor to suck the old stuff out and replace it with new fluid. Since that won't get any fluid already in the p/s lines, you'll probably have to repeat the process every few weeks or so to cycle as much of the old fluid out as possible.
Not sure which p/s fluid you can use, but I'd guess any Dexron III. But verify that from your owner's manual, the dealer, etc. before you actually use buy/use it.
How many posts could a repost post if a repost could post posts?
Old 12-21-2005, 09:07 AM
Mein Auto: 540i
Talking power steering fluid
thanks for the info.
Old 12-22-2005, 08:14 AM
psychop's Avatar
psychop psychop is offline
Fastest 528iA in the EU;)
Mein Auto: E39 528iA
"Every few weeks" sounds bit long to me.
More like, 3 seconds of the engine cranking. This will mix the new fluid from the
reservoir and fill it back with the used one coming from P/S lines. Did that and
it is actually quite simple method but the problem is that you waste much more
fluid than is contained in the system. I was left with 4l (around 1gal) bottle of the ATF
from my previous car and i've used it all to replace and flush the power steering.
E39 528iA/Steptronic,Professional DSP,Comfort Seats,Soft Leather,Xenon,PDC
Old 12-22-2005, 09:25 AM
Mein Auto: 540i
ps fluid
How much roughly does the power steering system hold?
Old 12-22-2005, 11:32 AM
psychop's Avatar
Service manual states that it's 1.2l total in the system but i've used four times that
to flush the system.
The other method of getting the fluid out of the system is to disconnect RETURN hose
from the expansion tank fasten it REAL WELL (high pressure!) to some kind of container
and crank engine for second or two to pump oil out of the system.
The fastening bit is really important, otherwise you will end up with oil everywhere, not only engine compartment.
Old 12-25-2005, 04:33 PM
Mein Auto: 540i
thanks for the info
Old 09-25-2011, 05:12 PM
jfallon jfallon is offline
Mein Auto: BMW 2004 X5
Power Steering Fluid
Where is the reservoir for the power steering fluid?
Similar Threads
M3 Power Steering system question. GavYo E46 M3 (2001-2006) 7 07-04-2005 04:35 AM
Power steering fluid is BLACK!!!!! TimDogg 3 Series / 4 Series 11 10-01-2003 04:09 PM
What type of fluid to use for Power Steering on E39 Mz3bo 5 Series 4 09-03-2003 07:39 PM
