Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 12-30-2005, 04:34 AM
mancm5 mancm5 is offline
Mein Auto: bmw m5 e39
oil change
what oil do i put in a m5e39 2000wreg will mobil 1 0/40 do
Old 12-30-2005, 02:55 PM
Bruce Bruce is offline
Mein Auto: 88 E30 M3.2, 08 451
depends on the build date. if it is 3/00 or earlier you need the 10/60 oil. Otherwise consult the owner's manual. It will tell you what you can use.
Old 12-30-2005, 03:47 PM
thaks it neads 10/60
Old 08-16-2006, 10:52 PM
tada540i tada540i is offline
Mein Auto: 2001 BMW 540i M-Sport 6sp
How about for 2001 BMW 540i ? Which oil should I use and how many quarts?
Old 08-17-2006, 12:18 AM
Jon@TheMshop Jon@TheMshop is offline
Past Sponsor
Send a message via AIM to Jon@TheMshop
Mein Auto: '98 M3 Turbo '07 335i
8qts of 5w-30
Old 08-17-2006, 12:23 AM
thanks =]
Old 08-18-2006, 03:43 AM
gtx510 gtx510 is offline
Mein Auto: ist kaput
Not your regular old xW30. Mobil1 5W30 or 10W30 need not apply...
Look for stuff that says LL-01 on the back of the bottle.
Castrol Syntec 0W30 or Mobil1 0W40 for instance. BTW, the Castrol stuff is better.
Motul or Redline 5W40 would also be good choices.
www.myoilshop.com
www.motorspot.com
Or at least look for a ACEA A3/B3 rating...
And if you want more protection use the Castrol TWS 10W60 that BMW rec'ds the rest of the world uses.
Or find a place to get Liqui-Moly 10W60..
www.interautopartssd.com/liquimoly.php
Or mix a 10W60 with another synthetic....
google for more info... www.google.com
Old 08-18-2006, 09:04 AM
opps, I used mobil-1 full syn 5-30, and I used MANN oil filter.
It took 7qts instead of 8qts.
Old 09-11-2006, 04:24 AM
m5q8 m5q8 is offline
Mein Auto: 540i Auto
Take my advice plz
I used Castrol RS 10W60 FOR my M5 2 years before I sell the car ..
Castrol RS = TWS (RS) IN GULF MIDLLE EAST.
I change it every 10k kilometer because the weather in kuwait is very hot it is to go 51 c
(HELL)
some of my friends put another oil because they told me its very expensive ,
I told him you have M5 ,, they told me no problem all oils
and know they cry the engine damage ,,
one of them buy used engine about 10,000 $ ,,,,
dont try another oil (castrol or mobil 10w60) castrol is best for me ,,
and you should check the guage for oil is not over the mark (not over max or under min)
and dont afraid about the engine when the it told you check engine oil level add one litre of oil ,,, all M5 less some oil when you race or very long street ,,,
Similar Threads
Oil change interval kashrahman E60 / E61 (2004 - 2010) 12 05-16-2016 05:01 PM
Oil change, oil level indicator. mishenka E90/E91/E92/E93 (2006 - 2013) 3 06-03-2007 02:43 PM
Post break in oil change vadimv E46 (1999 - 2006) 10 01-30-2005 10:42 PM
