E36 (1991 - 1999)
Old 01-03-2006, 02:42 AM
digiblue digiblue is offline
Mein Auto: 1994 318is
'94 318is No dash gauges Help Please!
This morning going to work everything was good. Then when leaving work, No tacho, no speedo, no fuel, no temperature, no fuel economy guage, no oddometer, no tripometer. But everything else seems to work. Why would this happen suddenly? Checked the fuses, all seems in order. What should I do next? Take it to BMW service centre, or auto electrician? Had this car since end September '05. So a bit new to me. OK hope to hear from someone!
Old 01-03-2006, 09:28 PM
eurocar318's Avatar
eurocar318 eurocar318 is offline
Send a message via AIM to eurocar318
Mein Auto: 94 E36 318is
take it to a cheaper guy that knows his stuff....the dealer will charge way too much
Old 01-03-2006, 11:20 PM
e36chick e36chick is offline
Mein Auto: 93 bmw 325is
when i got my 325is only the gas guage and speedo worked, when taken apart and tried to get tac and engine temp to work, when the cluster got put back in, nothing worked as described by you. took to the dealership, told to get a new cluster, ($700 quote for parts, not including labor), got a new cluster at a junk yard out of another bmw, everything worked, that only costed $100.
my fiance does all the work on my car, replacing it only takes about 5 - 10 minutes. he did it in a parking lot while i was at work.
Old 01-05-2006, 04:37 AM
No dash guages
Saw an Auto Electrican today. No joy there! Have to see an Instrument Electrican on Monday because of shutting down over Christmas - New Years break. This is getting sadder by the day, all I can see is dollar signs?
Old 01-05-2006, 09:43 AM
netdude netdude is offline
Mein Auto: 318i
my guages goes on and off once in a while... no idea what's causing it, but i've just left it alone. sometimes it'll all turn off, car runs fine, but no idea how fast i'm going or anything... after a few minutes, it comes right back.
Old 01-05-2006, 07:24 PM
mikey36m3 mikey36m3 is offline
Antagonist
Send a message via AIM to mikey36m3
Mein Auto: Bat Mobile
Sometimes when I start the car in the morning the tach will freeze for about 30 seconds, nothing too major.
Old 01-10-2006, 05:42 PM
dash gauges
I have been to or rang up a few auto electrics this week. Some have been recommended by the ones that cannot help, but when you go there they say no they cannot do it. I have been from pillar to post. I might have to ring BMW service centre next week. But I am a little scared, I can see dollar signs floating in the air, you know what I mean. No body wants to touch it.
Old 01-26-2006, 06:58 PM
Instrument cluster
Finally got a new cluster, they say that you can't fix the modules. Very happy I am on the road again! Now I have a problem with the passenger side window. It won't work but you can hear the motor trying to move. Got quoted $350 for reconditioned window motor, surely there is another way. I have to take the door apart and see if I can nut something out.
Old 01-28-2006, 08:03 PM
Mein Auto: 318i
go to a salvage yard... usually you can find an old motor for less than 100 bucks
Similar Threads
what are the recalls on 95 e36?? nads12345 E36 (1991 - 1999) 28 11-27-2013 12:10 PM
'94 318is - Noob Questions - Howto Diagnostic AutoBahnLuv E36 (1991 - 1999) 3 08-14-2007 07:15 AM
Odd Warning light on dash? 1996 BMW 318is MightyWhitey125 E36 (1991 - 1999) 10 03-15-2006 11:45 AM
91 850i Heater Core Removal Instructions Wanted nicko 7 Series & 8 Series 1 10-18-2004 10:56 PM
Tire Pressure Gauges - Article by consumer reports. JSJAMALA 3 Series & 4 Series 0 07-20-2002 11:24 PM
