E46 (1999 - 2006)
Old 01-04-2006, 03:51 PM
texlnghorn texlnghorn is offline
Mein Auto: 323i
Final Stage Resistor Instructions
I appear to have the dreaded AC fluctuating fan speed problem and I believe it might be a faulty final stage resistor. I did a search and found lots of people talking about how the instructions on this site helped them but I cannot locate the repair instructions. I found these instructions for a 540.
http://www.540i6.com/finalstagereplacement.html
Is the procedure the same for an E46 Bimmer? If not, where can I find the instructions for the repair of the final stage resistor?
-Mike
Old 01-04-2006, 06:50 PM
alpinewhite325i alpinewhite325i is offline
I love my beautiful wife.
Mein Auto: '01 325i
I don't think it's that easy on the e46.
'01 325i
5sp
I Love my beautiful wife
moonroof:
Old 01-04-2006, 08:31 PM
Mein Auto: 323i
You're right, it's not that simple. I found a good step by step discussion with photos here:
http://forum.e46fanatics.com/showthr...ht=final+stage
Old 06-01-2008, 06:50 AM
maryper70 maryper70 is offline
Mein Auto: 2001 325I
Final Stage resisting replaced for my 325I 2001 E46
I just wanted to take the opportunity to say thank you to all of you, this is a great forum. I was having some problems with my heating and cooling fan when my car was off. This issue was driving me insane as the battery was dying on me every morning. I searched that problem that I found the solution here , it was very helpful I managed to get the Final Stage at the dealer and able to replace myself, I am a chick so It was a little bit challenging as I needed to remove the Glove Compartment and the space was very uncomfortable. I saved myself a lot of money , If I would had bring my car to the " stealer" it would had cost me around $ 400. I am so proud that I did it . The problem has been resolved.
Thank you all this place is great
Maria :thumb up:
Old 11-22-2008, 06:11 PM
A325iBMW A325iBMW is offline
Mein Auto: 325i
Final Stage Unit
Mixed emotions.....the post on the final stage unit was perfect. It helped me demystify my possessed 325i ventilation system. Thanks a million.
I'm not a gear head but I got to the FSU in about .5 hrs but couldn't figure out how to get the FSU past the plunger linage(?) until I got fed up and used a screwdriver. All's well that ends well. 300-1200 in my pocket and my ventilation system works fine
Old 04-17-2009, 12:53 PM
Angie Braden Angie Braden is offline
Mein Auto: 528I
Does this procedure work for a 5 series? I am having this issue also and It's driving me crazy!
Old 04-17-2009, 04:47 PM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
It's funny, a brand new resistor was in my glove box in when I bought the car. I didn't even know what it was until 2 mths later when my HVAC became possessed, and I stopped using it as a paper weight and put it in. I guess the folks at the stealer that sold me my car hadno confidence in the resistor so they inlcluded one
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 04-17-2009, 04:49 PM
kunal_D's Avatar
Please refer to the first post
Old 11-10-2009, 04:56 PM
mromero_05 mromero_05 is offline
Mein Auto: 2001 325ci
I'm new to all this, so please forgive my ignorance. I have a 2001 BMW 325ci (she's ready and a beauty) I'm assuming that's considered an E46, correct? If so I guess I can use the guide provided in this forum to change out the Final Stage Resistor...?
I'm new to all this, so please forgive my ignorance. I have a 2001 BMW 325ci (she's red and a beauty) I'm assuming that's considered an E46, correct? If so I guess I can use the guide provided in this forum to change out the Final Stage Resistor...?
Old 11-10-2009, 05:02 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
  • Yes, a 2001 325Ci is a 3-Series E46.
  • Yes, the subject of this thread (except the 5 Series DIY on the very first post) applies.
  • No, it is considered poor form to duplicate your posts...
2006 325Ci
Old 11-10-2009, 05:03 PM
2006 325Ci
Old 11-10-2009, 06:57 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Interesting.
Jeff R.
Old 10-12-2011, 04:44 PM
Bombay Badboy Bombay Badboy is offline
Mein Auto: WHT 2001 BMW 325xi
Hi i have 2001 e46 325xi, My heater has been fluctuating for quite some time.... Then one day early last week it shut off while i was driving ( and changing gear, if that makes a difference)
I ordered another FSU and installed it today, but still have the same problem..
I checked fuses 28,62,63, all were okay. What else could it be? If i want heat as of right now i need to crack my window open which then sucks air from the vents.....
Old 08-27-2012, 06:06 PM
bgorham bgorham is offline
Mein Auto: 01 325I
Red face A/C fan runs continually in off position
I just replaced the final stage resistor on my daughters 325I and the fan started running immediately after I plugged the new one in, problem is the car is turned off and the keys are out of the ignition!
What gives?
Similar Threads
How to remove plastic bracket holding Final Stage Unit? drkongt E39 (1997 - 2003) 2 07-30-2009 10:16 AM
final stage resistor install Jdogg E46 (1999 - 2006) 9 06-01-2008 06:52 AM
Final Stage Resistor RakNaks E60 / E61 (2004 - 2010) 0 02-05-2005 06:12 PM
Another Final Stage Resistor Bites The Dust EdCT 3 Series & 4 Series 16 12-21-2004 11:11 PM
I just fixed my 96 328i's blower motor final stage resistor erguy63 3 Series & 4 Series 0 09-12-2004 02:56 AM
