Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 01-10-2006, 09:15 PM
RamD7502 RamD7502 is offline
Mein Auto: 1975 2002
1975 2002 tech questions
I am currently rebuilding the engine in my 1975 '02 and I have a few questions. I started with an obviously rebuilt engine with a knock. After tearing it down I discovered the #4 rod bearing was toast and the crank case and crank were destroyed beyond repair. So I decided to completely rebuild it. I found a rebuilt short block from a TII and found a 1974 intake (slightly modified) and got a new Weber 38 carb with an electric choke and I added a new cam (upgrade, but I forgot the degree). I polished the heads and polished the exhaust manifold and basically worked really hard to get it looking nice. I am in the process of putting it back together and found the following problems:
1. The intake doesn't have the inlet and outlet for the water hoses. What do you suggest I do?
2. The intake is not as tall where the carb mounts which is causing the throttle gears to hit the intake. The existing spacer won't work, so what do you suggest I do? Do I need that much clearance? It only needs to come up about 1/16"??
3. What do I connect the electric choke to?
4. I want to add a water temp gauge and the existing hole in the splitter right under the head is not big enough. Is there another place that I can put it or should I bore out the existing hole and make it fit?
Any and all help is greatly appreciated. Lots of time and money have been invested!!
Similar Threads
Questions on 1975 BMW 2002 M3_413 General BMW Questions 12 12-05-2006 05:02 AM
Time prevents a thorough search...Some 2002 X5 Questions.... KimTT X5 E53 (1999 - 2006) 13 03-09-2005 09:32 PM
1972 2002 Tii 2 Complete Drive Trains!!! weldunn007 Cars - Private Party 1 02-28-2005 02:41 PM
Emulsified Oil in 2002 325i KD4VS E46 (1999 - 2006) 5 02-18-2005 12:44 PM
URGENT REQUEST for 2002 M Coupe owners! loki E36/7 Z3 (1996-2002) 3 10-16-2003 08:32 AM
