Old 01-17-2006, 05:48 PM
hishamrazzak hishamrazzak is offline
Mein Auto: 520 BMW
Question A wierd fuel leak
Hi Guys,
I got a weird fuel leak coming out some where under the car /under passenger front seat.
I got 520i 2002, similar to 525. The leak happened only once, I left the car for 4 days unattended inside garage and when started engine yesterday I smelled petrol and found the fuel was leaking , I took the for a spin and back . Leak stopped completely. No leak this morning or even at work’s parking area. I sneaked under car and looked through plastic cover using a torch, I saw a thin black hose and some kind of cylinder or some thing similar as I couldn’t see the whole stuff due to the plastic cover. The area is very very dry you cant even smell the petrol. The leak was really bad , about 10 drops/second….now no leak.. any advice is much appreciated.
Old 01-20-2006, 08:02 AM
psychop's Avatar
psychop psychop is offline
Fastest 528iA in the EU;)
Mein Auto: E39 528iA
Intermittent nature of this leak may suggest that it's not the main fuel circuit leaking.
It could be the fuel tank venting system letting some fuel through. You need to pull
the covers and carefully inspect all fuel system components - risk of fire!
E39 528iA/Steptronic,Professional DSP,Comfort Seats,Soft Leather,Xenon,PDC
Old 01-20-2006, 09:42 AM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
I recently had a petrol leak that was as significant as you described. For weeks I smelled petrol fumes but there was no apparent leak. The leak was only discovered after I had filled the tank up then the leak was pronounced! Turned out that the gasket sealing the fuel pump access panel - located on top of the fuel tank and accessed through the interior of the my 540i -was the problem. Replaced the gasket - no more problem. Obviously there are a number of potential problems but this is one place to look.
Old 01-20-2006, 01:55 PM
Mein Auto: 520 BMW
Many thanks Gents..points taken & checked all componenet , seems some clamps need to be tightened.
I got another question?
the car drips oil, very minimal, one or 2 drops /day when i move car from garage.
i looked under the car + oil type and can confirm that the leak is comng from gear when meets with engine , and the oil is the transmission oil/gear. Is it serious? do i need to fix it ?
the car under full mech warranty for anoher 2 yrs, but i dont want the mechanics to mess around and i might get bigger issues after fixing( happened b4) as long as the problem is not serious and i can live with it - although wife giving me a hard time to clean drops :-(
Old 01-20-2006, 07:46 PM
psychop's Avatar
Well, if this is the transmission oil leaking i'd be definitely looking into fixing this ASAP.
Mostly because, unlike as in the engine, there is no reliable way to check oil level in
the transmission on daily basis
Old 01-20-2006, 08:10 PM
Mein Auto: 520 BMW
thanks psychop..i will consider your advice and see garage on Monday...Regards
Is there any Diagnoses the gear indicates the need to be checked b4 failing...in other car-Nissan Maxima- the auto trans gave me a good cry to add oil!
Similar Threads
DIY:1997 528i Fuel Pump Replacement(E39) GOKOOLJAPAN 5 Series DIY 15 09-24-2015 07:06 PM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 05:52 PM
Fuel Tank Leak peplow Classic Bimmers 0 09-15-2005 02:08 AM
