Old 01-18-2006, 06:33 PM
650/drive 650/drive is offline
Mein Auto: 650i con,spt,6spd,blksaph
Tires Tyres and size does matter
Waiting for Feb. delivery of my 650 conv. I am not a big fan of the elipsoid(?) rims with the sport pkg. So in the mean time I found some m6 wheels to put on until I find exactly what I want. Here is the question, the sport package calls for 245/40 and 275/35 on the back. The m6 comes with 255/40 and 9.5 (vs. 9.0) 285/35 on the back.
1.)Should I use the "stock" tires (from the sport package) or upgrade to bigger for the m6 wheels
2.) Will the larger size effect speedo,handling, ride. I am not into the bling bling, more into ride and handling.
3.)What tire brand, size, run flats?
Thanks in advance from a newbee.
2006 650i conv. black sapph, cold, sport, HUD, 6spd
Old 01-18-2006, 06:37 PM
Nevervana's Avatar
Nevervana Nevervana is offline
Banned
Mein Auto: Jet Black 650i
I was about to get some new tires for my 650 and the guy told me to get:
245 35 20 front
285 30 20 rear
I hope he knows what he's doing because your numbers are different...
Old 01-18-2006, 06:46 PM
Malibubimmer Malibubimmer is offline
Officially Welcomed to The 'Fest!
Mein Auto:
The sizes Nevervana has posted are "plus 1," which maintains approximately the same rolling radius with a one inch larger diameter wheel. The sizes 650/Drive has posted are just fatter tyres, assuming they are on the same size wheels as the ones being replaced (19 inch).
I am getting my info from the 2006 6 series brochure under sport package. It would not surprise me for it to have a mistake, but I did double check it to be sure. 19x8.5 19x19.0 245/40r/19 275/35r/19 . I assume this rim will fit multiple size tires?
Old 01-18-2006, 07:26 PM
cobradav cobradav is offline
Mein Auto:
Those are correct and as delivered. Go to tirerack.com. Pick a nice Michlein PS2 or the OEM Bridgestone tire in the stock size. Go to the specs. You will get a nice list of that tire in all the sizes offered and the dimensions, including diameter (stay within 3%), and the width recommendation (usually expressed as a range such as 8-9.5"). Check all the brands and tire types you are considering as the mfrs do not all produce them in the sizes you want. You could go up in diameter by 2% and probably bring your speedo and odo right on the money as BMW is high by 2% on stock tire size.
Similar Threads
HELP ? What size wheels and tyres fit my new 1988 318i nicklovett Tire Rack's Tires, Wheels, Brakes & Suspension 0 10-04-2005 06:53 AM
