Old 01-21-2006, 01:42 PM
MPOWEROH MPOWEROH is offline
Mein Auto: M Coupe 01
Oil Change S54 Wheres the Drain Plug?
Okay. I own a 2.8 Z3 and can eaily identify the location of the oil drain plug. When I lifted my new 01 M coupe with the s54 motor it all looks different. For starters the bottom of the motor is covered with a plastic shield. There is no 17 mm drain plug visible (as indicated by my Bently manual). I do see a allen head socket plug next to a round cover (approx 3" in diamieter). Can some one advise as to the location of the drain plug. Is it necessary to remove the plastic covers? Removal looks like a lot of work just to drain the oil.
Old 01-21-2006, 02:57 PM
Ron Stygar's Avatar
19,585 Miles
There is a plastic door that swings down exposing it. Many of us have removed the plastic under body cover for the reason you mentioned.
I initially modified the car for jacking before I removed it. The second pic shows the oil drain plug access cover.
Old 01-22-2006, 03:11 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Or you can just use an oil extractor.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 01-24-2006, 10:09 AM
fpa1974's Avatar
fpa1974 fpa1974 is offline
Learning to drive...
Send a message via AIM to fpa1974
Mein Auto: 02 M Cpe,03 325iT,05 330i
Be careful with the plug. You can strip the head very easily or worse.
Florian
2002 M Coupe Estorilblau
2003 325iT Graygreen
2005 330i ZHP Imolarot II
368S/74
Old 10-27-2012, 05:49 PM
JayMac JayMac is offline
Mein Auto: 1997 328is
I am in the process of sorting out an s54 for an engine swap to my e36 and came across this thread. Dropped the pan today in advance of rod bearing job and discovered I have a pan that has been helicoiled.
I am trying to get the plug out but it does not want to move. How much torque will this thing take? Any ideas, maybe a little heat or just more slow steady pressure?
Jay
Old 10-28-2012, 02:37 AM
Pinecone's Avatar
M Mad
Why bother? Get an oil extractor and never touch the plug.
I have NEVER removed the drain plug on any of our BMWs.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-28-2012, 07:10 AM
Randy Forbes's Avatar
Investigative Tinkerer
Jay
I'm really surprised to see a stripped pan thread, as the hollow bolt usually breaks so easily (so I've been told). Some ham-fisted clown must've cross-threaded the bolt going back in (likely breaking off its head) and then did an amateur job with the Heli-coil.
If you're dead-set on doing it right, drill out the bolt, it should be soft enough, staying exactly on the hole's centerline. Once the bolt is out of the way, you can unravel the insert by pulling/unwinding the HARDENED steel coil from the inside of the pan.
Take care that your unraveling process does no further damage to the threads, or you'll wind up with too big of a hole and have to go up a size for the drain plug.
The insert should not extend beyong the aluminum casting, and should've broken off "square" to allow the bolt to pass through the end of the insert__that's what likely jammed up the installation you have before you.
Or take Terry's advice and put the whole thing out of your mind, commiting all future oil services to be done with an extractor...
Randy Forbes
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
Old 10-28-2012, 07:46 AM
Thanks guys, I soaked it in PB Blaster and it finally broke free. Randy, the plug here was solid and I am cleaning all this mess up so you don't have oil all over the place when I bring this down to you. I am guessing that the plug is not OEM either due to the coil not being trimmed. Pinecone, I got most of the oil out while I had this engine sitting in the back of my Jeep. Cold 10w60, if that's what it was did not flow too well. Luckily next time it would be warm. This engine had 114,000 on it so the bottom was coming off anyway and I am taking this down to Randy for the rod bearings. Here is what the pan looked like before and after.
I can't speak for what was done or where it has been, length of time sitting on a shelf waiting for a home, but I just have a vision of the temp changes causing moisture and forming a nice black goo that no extractor is going to get out. I have some wonder picture of a goo filled accusump that never saw anything but synthetic oil. If this had been a used car purchase I would have drained the oil flushed it with clean oil and some TEC 2000 and changed the oil again. http://www.tec-2000.co.uk/tecinfo/en...ngineflush.php
Old 10-28-2012, 10:58 AM
Not much makes me happier than working on a clean car/engine/parts. Cleaning is good!
If you want to leave the drain plug heli-coil alone, I will take care of it while it's here.
Randy Forbes
Old 10-28-2012, 05:00 PM
Pinecone's Avatar
M Mad
Probably would be suspended if the engine was run more often and come out if the oil was hot. Or it is that hard to move, it will just sit there and do nothing.
Too many other things to worry about.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Similar Threads
Is my 4.8is a lemon??! ZenX5 X5 E53 (1999 - 2006) 68 09-15-2007 08:08 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
LOW OIL LEVEL warning roadie 5 Series 16 04-04-2005 07:16 PM
Panel under Oil Pan Drain Plug OrientBlau E46 (1999 - 2006) 5 02-24-2005 12:47 AM
S54 oil drain plug safety wire Ron Stygar E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 4 01-18-2005 06:54 AM
