Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > The MINI Board
The MINI Board
The Mini Cooper Forum
Old 01-21-2006, 08:49 PM
///ACS330Ci's Avatar
///ACS330Ci ///ACS330Ci is offline
Need4Speed
Send a message via ICQ to ///ACS330Ci Send a message via AIM to ///ACS330Ci
Mein Auto: ACS/M-Technik 330Ci
Got sways? =:-)
Find out about my car here.
Old 01-27-2006, 08:37 AM
Dirtboy's Avatar
Dirtboy Dirtboy is offline
Ring Junkie
Send a message via ICQ to Dirtboy Send a message via AIM to Dirtboy Send a message via Yahoo to Dirtboy
Mein Auto: E46 E83 E30- all M sport!
got brakes???
Nürburgring info
Old 01-27-2006, 04:45 PM
Need4Speed
Brakes are for poofs!
Old 01-27-2006, 04:46 PM
Need4Speed
Old 01-28-2006, 02:01 AM
Dirtboy's Avatar
Ring Junkie
What's up, no front sway for the Mini???
Nürburgring info
Old 01-28-2006, 07:22 AM
Need4Speed
No, you can buy them but they're not really needed.
From Webb Motorsports webpage ...
"I only recommend doing the rear swaybar. The purpose behind the rear swaybar is to dial out the inherent understeer, which most new cars are programmed with. Why? Because if you enter a turn too hot, the car goes straight when you turn the wheel - the tendency then is to lift the throttle, which transfers more weight to the front and gives more coefficient of friction to the front contact patch, letting the car turn in. It isn't the fastest way through a turn, and it certainly isn't the most fun way through a turn. That's where the rear bar comes in. Thinking on a twisting body model, if you apply force to the outside, or loaded wheel, and you have a stiffer rear bar, it will do two things: first, it will lift the inside rear wheel, reducing the rear coefficient of friction, and second, it will transfer load diagonally to the inside front wheel. This makes the car neutral. It has a secondary benefit of acting like a cheap limited slip differential if the unloaded front wheel is the power driven wheel.
If you change both the front and rear swaybars, the car will still understeer, but it will handle flatter - less body roll. That's the reason I don't recommend doing both the front and rear swaybar - the most dramatic thing you can do to the car is make it neutral, not flat."
Here's another pic ...
Old 01-28-2006, 07:43 AM
wwb4's Avatar
wwb4 wwb4 is offline
Mein Auto: It's constantly changing.
Originally Posted by ///ACS330Ci
That's a beautiful thing there.
Old 02-14-2006, 05:52 PM
Need4Speed
Similar Threads
UUC Sways on 03 ZHP (day 1 report) adc E46 (1999 - 2006) 5 06-14-2005 09:20 AM
UUC Sways - First Impressions (Long) Ack 3 Series / 4 Series 16 08-11-2003 05:24 AM
UUC Sways & G2 Caliper Paint Installed Ack Do-It-Yourself H.Q. 16 08-08-2003 07:10 PM
Review: UUC Sways SONET General BMW 34 03-12-2003 08:06 AM
