E34 (1989 - 1995)
Old 01-22-2006, 08:41 AM
dopple dopple is offline
Mein Auto: m3, 525it
Octane ratings for 1995 525ti
I am going on a 2000 mile road trip in Feb and was thinking I may be able to get by with a mix of the top grade and mid grade fuels to save a little on gas cost. Running 100% of the best now. I dont know what the ratings are here in Colorado but does anyone else do that. My BMW is in top shape so I want to keep it that way. Only has 86k on it and was owned by a meticulous Doctor. I only put about 6k per year on it but it cost me 10k so I thought I should let it see some road since the touring wagon was created for that. I am going to a window cleaning convention in Mesa Ariz. and could save alot in gas going in the 318ti but it would not be as sweet a ride.
Also: should my mileage go up alot from the 22 I get around town on the highway. I though I measured highway once for the 525ti and it was only a couple mpg better on highway, maybe because of its weight?
Old 01-27-2006, 04:48 PM
breknraj breknraj is offline
Mein Auto: '90 535I 5 speed
As far as I'm aware, most, if not all, modern BMWs call for premium fuel in the owner's manual. While BMW did de-tune a lot of the models coming to the US so that they would run on regular, they will run better on premium. Most BMW engines run a fairly high compression ratio, so the higher octane will help to prevent knocking. I figure that If the company recommends premium, then that's what should be used.
You probably won't get the 26 mpg (give or take) that I usually see on my 535I (more weight with the touring, and smaller engine to drive it), but how much do you really think you'll save using regular between here and AZ? I'd be surprised if it saved you even $40 for the round trip. Treat these cars right, and they'll treat you right for a good, long time!
Bottom line, I'd put the premium in it for the trip, if that's what the owner's manual calls for.
Similar Threads
Another Long art: Rollover Ratings... motordavid X5 E53 (1999 - 2006) 1 12-19-2004 01:56 PM
Octane vs. altitude vs. mpg Robinlawson General Automotive Forum 2 10-11-2004 07:44 AM
Can higher octane gas cause engine noise? jw General Automotive Forum 15 08-10-2004 09:04 AM
525 I: mileage/US Gallon: Octane number level? pac 5 Series 9 05-27-2004 09:45 AM
DOT releases SUV rollover ratings TeamM3 Off-Topic 57 02-06-2004 07:53 PM
