Cylinder #5 Misfire - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 01-24-2006, 06:25 PM
Evil Spoonman Evil Spoonman is offline
Send a message via AIM to Evil Spoonman
Mein Auto: 1996 328is
Cylinder #5 Misfire
Hey folks.
Looking at buying an E36 1997 BMW M3 here. There's a cheap one around that is in good order, except it has the check engine light on and the ODB2 outputs a "Cylinder #5 Misfire" error.
Now I'm thinking this might just be a spark plug. The car is at about 95,000 miles, so it's quite feasible. If so I'd just go in there and replace all the spark plugs. But before I buy it, I figured I'd ask you folks if you knew of anything else that could be likely issue causing that error. The car does run rough 'sometimes', apparently, though I have no idea when that 'sometimes' is.
Any help much appreciated - Julien
Old 01-25-2006, 11:09 PM
MATT95M3 MATT95M3 is offline
Mein Auto: 95 COSMOS M3
the plug may be bad which of course is an easy fix, possible that the plug isnt torqued properly, which may allow the car to run well at high rpm but possibly poorly at low rpm, also a common problem is a bad valve cover gasket which allows engine oil to slowly drip into the plug well, when the hot oil drips in the well, it can short out the plug. then theres the possibility of a bad ignition pack or ground but if i were you i would ask the seller to change the plug and be sure its torqued to 18 ft/lbs if there is oil there you can't miss it good luck!
1st gear, 2nd gear, 1st gear = the worst sound ever
Old 01-26-2006, 12:20 AM
Borgiulo Borgiulo is offline
Banned
Mein Auto:
h
Old 01-26-2006, 12:25 AM
Banned
Mein Auto:
Thats hella funny, my roomate just bought that M3 for $7,500 cash money.
He changed the spark plugs(problem solved)
The car ****in rips!!!!!!!!!!!!!
Old 01-26-2006, 09:01 PM
CrazyFool CrazyFool is offline
I'm A Badfish!
Send a message via AIM to CrazyFool Send a message via Yahoo to CrazyFool
Mein Auto: M3/R1
yes i did... you can see my signature... it was a quick $10 fix, now the car runs like brand new. i also got lucky and talked him down to $7500 since i brought cash... (Borgiulo's idea)
///M3 Carbon Black - SMG - Cinnamon
R1 2007
- Raven
Old 01-27-2006, 09:10 PM
whitem3/4 whitem3/4 is offline
Mein Auto: 07 X3, 05 ZHP, 09 911S
Originally Posted by Evil Spoonman
Hey folks.
Had this same error message in mine last May. It was the Spark Plug Rubber Connector Boot which is the rubber boot that connects the spark plug to the ignition coil. They get old and cracked from the heat/cool cylces and create a short to the block instead of the plug. You could pull it out and see if it looks bad. Its about a $10 part. Other misfire things could be bad plug or coil pack.
98M3/4 2005 One Lap Of America-Lap Dog, UUC EVO3 ssk & clutch stop, UUC Sway barbarians, GC School/Track Coilovers, new OEM RTABs w/ GC shims, X brace
One Lap Pics
2007 X3 3.0si, 2005 330iZHP, 2009 911S
Old 02-02-2006, 11:16 PM
Score man. Total score. Yeah I hoped it was the plug. Ended up not approaching the deal because another one surfaced. Glad to hear I wasn't totally off though. Hope to see you rippin around the area.
Old 02-03-2006, 03:19 PM
Mervon Mervon is offline
Mein Auto: M3
Are you serious, you got a 97 M3 for $7500. Wow Congrats on that, I live in San Diego and have been searchin quite a bit for a M3, I could never find anythin that cheap
Old 02-04-2006, 09:37 PM
I'm A Badfish!
Mein Auto: M3/R1
yes i took a chance and i was very very lucky...
R1 2007
- Raven
Similar Threads
misfire asf4life E46 (1999 - 2006) 7 01-08-2009 04:28 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 05:52 PM
P1351 Misfire Cylinder 5 With Fuel Cut-off BeachBum E39 (1997 - 2003) 4 12-18-2005 12:38 PM
Help with a misfire? (M50 vanos 325i) J///MR Do-It-Yourself H.Q. 0 10-18-2005 04:51 PM
