E34 (1989 - 1995)
Old 01-25-2006, 02:03 AM
willietopz willietopz is offline
Mein Auto: 1989 535i
Clutch on the floor
My 1989 535 clutch went to the floor and will not come back up. It has plenty of break fluid but there is no pressure at the clutch.
Old 01-25-2006, 02:11 AM
supark supark is offline
Mein Auto: Falcor
slave cylinder would be my first guess, a failed clutch would by next.
Old 01-27-2006, 05:11 PM
breknraj breknraj is offline
Mein Auto: '90 535I 5 speed
Exclamation
Before you assume that it is either of the cylinders, take off the lower dash cover, under the steering wheel. Take a look at the mounting bolts for the master cylinder. I had the exact same symtom a few years ago, and it turned out to be the master cylinder had come loose from its bolts, hence the pedal going to the floor and staying there.
The bolts were still in the holes, so I put it all back together, with some blue loctite, and I haven't had a problem since!
Similar Threads
The Husband Store hockeynut Off-Topic 7 03-01-2007 10:36 AM
Floor mats a slippin EMD2006330I E90/E91/E92/E93 (2006 - 2013) 9 07-20-2005 12:45 PM
Semi OT: Floor jack maintenance? BMcCoupe E36/7 Z3 (1996-2002) 6 06-17-2005 08:27 AM
Thinking of building a house? Here's my experiences... (very long) OBS3SSION Off-Topic 26 01-22-2005 12:41 AM
Garage floor is a mess...advice? caylan E36/7 Z3 (1996-2002) 2 03-05-2003 05:06 AM
