Old 08-05-2008, 01:35 AM
UKTONZMAT UKTONZMAT is offline
Send a message via MSN to UKTONZMAT Send a message via Skype™ to UKTONZMAT
Mein Auto: E39 530i
My 2003 E39 UK 530iA Alarm issues
I've had this car since new, bought it in the UK and exported it last year when I emmigrated to New Zealand - anyway - thats all irelevant. I've had alarm issues on this one since new - and the dealers cannot find whats wrong. I'm going to try and disconnect this bonnet (hood) switch, if I can find it. One thing I have learnt to do to stop the alarm going off, is to get out of car, lock it, then unlock it and walk away. As long as you don't open any doors when you unlock it, the car automatically locks itself after about 2 minutes and the alarm doesn't go off. I've tried the old "double press of the key" to disable the interior sensors, but that doesn't work - the alarm still goes off. Not sure why the alarm doesn't go off when I do my little lock, unlock, walk away trick - but it has worked for me. Does anyone know if there are other sensors - i.e. in car parks it goes off so much - possibly when other cars drive by?
Old 08-18-2008, 01:29 AM
Mein Auto: E39 530i
I unplugged my Hood (Bonnet) switch - and the alarm has not gone off since - switch feels a bit stiff (posibly corroded after shipping the car across the world in a container) - so removing my switch has saved me about $1,000 NZD since the dealer wanted to change the interior ultrasonic sensors!!! - thanks Bimmerfest for such a brilliant forum!!
Old 08-18-2008, 07:48 AM
dbruce dbruce is offline
Mein Auto: Sold 00 528iT, 06 Mazda6
I had to pull the plug on mine last month also. It's a piece of crap. I've installed hood switches for alarms and they are tiny and simple and last forever. Why this thing is so big and such crap, I'll just add to my BMW mystery list.
Old 10-20-2008, 07:28 PM
PiscesBMW PiscesBMW is offline
****-M-W
Mein Auto: 1998 BMW 528i
Question How about this for an issue...
Drive home. Park Car. Set Alarm. No issues.
Go to sleep.
Wake up in morning.
Put key in keyhole on drivers side. Turn Left to deactivate/unlock.
ALARM GOES CRAZY!!!
Turn key Right to re-engage alarm. All is quiet.
Turn key Left to deactivate/unlock.
Alarm is silent.
I get in and drive away...
No problems again until I reset alarm.
I have a little "key hole dance" that I do where I turn the key quickly from left to right back to left again (Disengage-Engage-Disengage) where the alarm will go off for about a half second before i disengage it again but I'm sure it's still annoying as hell to my neighbors.
Same issue with the key fob button. Alarm will go crazy until the keyhole dance is performed to appease the Bavarian Gods of Security.
Any help please??
(Found out if you hold key in that left "open/unlock" position for more than 3 seconds, all windows roll down. Sweet!)
newb.M.W
Old 10-21-2008, 12:57 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
I noticed something about a month ago about the hood alarm switch.
If yours is acting up...it may not be the switch's fault...it might be from the insulation on the hood. If you lower your hood slowly, you'll notice that the tip of the hood switch DOES NOT touch any of the exposed metal on the hood...but actually pushes up into the insulation on the hood.
If you look closely at the insulation just above the exposed metal section of the hood (where the microfilters would be located on the e38 7 series)...and it is worn away...this could be what's causing the hood sensor to false trigger the alarm siren. The switch may not be pressed down far enough.
Name:	Hood Sensor wears away insulation.jpg
Q {BMW CCA Member #191509}
(SOLD)
Old 12-29-2008, 05:38 AM
****-M-W
Originally Posted by piscesbmw View Post
drive home. Park car. Set alarm. No issues.
Go to sleep.
Wake up in morning.
Put key in keyhole on drivers side. Turn left to deactivate/unlock.
Alarm goes crazy!!!
Turn key right to re-engage alarm. All is quiet.
Turn key left to deactivate/unlock.
Alarm is silent.
No problems again until i reset alarm.
I have a little "key hole dance" that i do where i turn the key quickly from left to right back to left again (disengage-engage-disengage) where the alarm will go off for about a half second before i disengage it again but i'm sure it's still annoying as hell to my neighbors.
Same issue with the key fob button. Alarm will go crazy until the keyhole dance is performed to appease the bavarian gods of security. :d
any help please??
(found out if you hold key in that left "open/unlock" position for more than 3 seconds, all windows roll down. Sweet!)
bump
newb.M.W
Old 12-29-2008, 05:46 PM
Warren928's Avatar
Warren928 Warren928 is offline
Boost addict
Mein Auto: M54 turbo Hi-5
I had a problem, or at least I thought it was. My German Shephard was in the bimmer and the alarm started going off. That is when I found out about the ultrasonic sensor shut off setting. Press the lock button twice and bingo, no shock or ultrasonic detection. I also like the window roll down feature, made famous by VW commercials.
Development of intercooled custom turbo , starting hp 421hp, @ 8psi w/H20-methanol.
Target: MK 1.5: 531 hp with h2O/methanol injection with 13-14 psi, cometic head gasket, re-mapped ECU with AEM piggyback
Old 12-29-2008, 07:06 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
I knew I wasnt the only one who saw those commercials . I like to make fun of them because BMW (and I bet some other car companies) has had that feature since the 80's
Old 12-30-2008, 08:46 AM
coolrahul coolrahul is offline
Mein Auto: 2001 530i
Red face
I have disconnected the hood switch and even disabled the motion sensor by holding the lock key for a second time after I locked the car. I still have the problem, at first the alarm will only come on for one bip then go off today in the morning it is little windy, and it is going off again. I have the newer motion sensor inside, is there any other switch other than the hood or the motion sensor? Is the hood switch normally closed so in other words the alarm system looks for the switch to be made when armed? Can I pull any particular fuse to disable the alarm but still lock the car? Please help
Old 12-30-2008, 10:01 AM
QSilver7's Avatar
I'm not sure if you've actually turned your tilt & interior motion sensor off by the way you describe what you did. You "press" the button twice, not hold it. Then you say that it is a windy day and the alarm went off...which could indicate that the tilt sensor was NOT deactivated....so let's do a quick test.
Roll down either the front or rear window on the driver' side. Get out and lock the door (the way you said you did by "holding" the button a 2nd time). WAIT 30 seconds, then stick your arms into the car and wave them around. If the alarm goes off, it means that you have NOT deactivated the interior & tilt motion sensor.
Unlock the door (to stop the alarm) and reset everything and this time...PRESS the LOCK button TWICE. Now wait 30 seconds again, and see if the alarm goes off.
Have you checked you car battery's voltage by doing TEST #9 (OBC must be unlocked)? A failing battery can also cause false triggering. Or the problem could be a failing alarm siren. It has a rechargable battery incorporated into it's design. If the car battery is failing...it will cause the alarm siren not to recharge properly. If the alarm siren senses a drop in voltage, it interprets that drop as someone trying to cut power to the car and will trigger the alarm. Or if the rechargable battery in the alarm siren is dying...the same could happen.
And if you've disconnected the electrical harness from the hood sensor...the system does NOT detect it or miss it then assume that something is wrong and set off the alarm. You can also disconnect the alarm siren itself...which is located in between the rear passenger side wheel well liner and the body of the car. You'll need to remove that wheel, then the liner to access it.
(SOLD)
Old 01-07-2009, 08:18 AM
kendu377 kendu377 is offline
Mein Auto: 1997 BMW 528i
Originally Posted by TimeOut View Post
It seems, I'm having the same issue now.
Last night, it was the first time my E39 was ever left parked outside overnight. Our garage is full of stuff because, we just sold our home and we're moving out next week.
It is a very quiet neighborhood and this morning with no apparent reason, the alarm just went off. I unlocked/locked the car with my remote and few minutes later, the alarm went off again. I again unlocked/locked the car and the alarm went off few minutes later.
I'm going to check the battery and hood sensor. Also, Is there a way to disable the motion sensor?
I have a '97 E39 and my alarm has been going off for sometime now. I brought it in to be serviced and was informed that one of the internal motion sensors went bad. Had the sensor replaced but the alarm is still too senistive and goes off anytime a loud motorcycle or truck goes by my house. I also uplugged the hood sensor hoping that this would do the trick but to no avail. I will try the double click.
Old 01-07-2009, 06:26 PM
sdavies88 sdavies88 is offline
Mein Auto: 540i / 6 and '95 NSX
I have intermittent alarm issues as well but an apparently different trigger. I have noticed that passing cop and taxi drivers when transmitting will set of the alarm. Anyone with same symptoms?
Old 01-07-2009, 09:42 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
My alarm went off, i traced it to worn door seal, moisture tarnished contacts, solved by spraying contact cleaner into switch and pushing to work the switch a number of times, years since still ok.
Old 01-13-2009, 07:21 AM
thielm thielm is offline
Mein Auto: 2003 540i Sport
I am having the same problem in cold weather on my 2003 540 and will try to disconnect hood sensor tonight. I just had it serviced yesterday so it's a bit suspicious it suddenly started happening.
However everytime it went of last night I noticed that when re-arming the light would blink rapidly, i.e. something is open. So I went around the car opened a door, re-armed, next door re-armed, etc and not until I did that with the trunk did it arm without blinking. 10 minutes later alarm would go off again and I repeated process to ensure the trunk would fix it.
Now I am inclined to think it is the trunk switch in my case, has anyone had this issue. And if so is the trunk switch easy to disconnect as well so I can test it tonight?
Thanks,
Mike.
Old 02-01-2009, 05:19 PM
trini4life trini4life is offline
Mein Auto: 97 528i
on my 97 528i i have had the same problem with the hood switch and solve it. my new problem is when i lock the car i dont get a chirp from the sirene but when i unlock with either the key in the door or the remote the alarm goes into panic mode and its hard to shut down. now i have to manually lock the car. anyone ever had that problem b4
Old 02-01-2009, 07:17 PM
TimeOut's Avatar
TimeOut TimeOut is offline
Mein Auto: '10 Genesis V8 Tech
Check your battery. The alarm acts crazy when the battery is going bad and unable to supply the correct voltage.
Currently hired as an organism that converts caffeine into computer code.
Old 03-12-2009, 07:37 AM
Ed540 Ed540 is offline
Mein Auto: 2002 540i Steptronic
problem solved
Thanks for the tip! I disconnected the hood sensor in front of the driver-side cabin air filter, and no more false-alarm problem !!!
Old 03-12-2009, 12:55 PM
E39Freak's Avatar
E39Freak E39Freak is offline
BimmerJunkie
Send a message via AIM to E39Freak Send a message via Yahoo to E39Freak
Mein Auto: 1998 Alpine White 528i
I haven't had any trouble with the alarm going off while driving, although last month on 2 different occasions it just started going off by itself a few times while parked in the driveway. The first time it happened I took alarm fuse out and replaced it. The second time it happened I turned on the car, let it run for about 15 minutes, turned it off, locked my car and has not happened since.
Old 03-12-2009, 12:58 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Low battery voltage has been known to trigger most of these problems.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 05-16-2009, 12:52 PM
razzy530's Avatar
razzy530 razzy530 is offline
Send a message via Yahoo to razzy530
Mein Auto: 2007 530i 6 Speed
im experiencing the same issue with the random alarm being trigerred. Ive narrowed it to the hood alarm sensor. Just have to replace it I guess Or maybe grease it so it travels smoother and has no awkward sitting position when closing the hood.
2007 E60 530i - Current
2002 E39 530i - RIP
BMWCCA MEMBER #397411
Old 05-16-2009, 01:42 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport cdn, F355
No grease....try flushing it out with some electrical contact cleaner spray. I would also examine the photo above and make sure it is fully depressed when the hood is closed. Otherwise simply replace it.
Old 05-17-2009, 10:35 PM
stewieh stewieh is offline
Mein Auto: E39 540iA
2003 E39 Alarm issues
my neighbours and I will be really happy if the hood switch fix works - I will have a try tonite - thanks to all who posted
Name:	bmw 540 P1030460.JPG
Old 06-12-2009, 10:57 AM
jewelerz jewelerz is offline
Mein Auto: BMW 525i
my alarm was going off all day several times a day so i removed the switch. so far so good....
Old 06-13-2009, 10:21 PM
Mein Auto: BMW 525i
ok removing switch worked like a charm
Old 06-27-2009, 09:42 AM
cagoguy's Avatar
cagoguy cagoguy is offline
Hawks RULE!
Mein Auto: '07 e60 530iA
Same false alarm problem started for me a few days ago. Removed hood sensor plug and it's fine.
2007 e60 530iA - Jet Black / Black Dakota - Premium - STEP - Cold - Sirius - 24k mi - CPO
2003 e39 530iA - SOLD @ 93k miles.
1997 e39 528iA - SOLD @ 145k miles.
Similar Threads
How to completely remove glove box (2003 E39) gixxer E39 (1997 - 2003) 1 07-20-2005 07:21 AM
Thinking of building a house? Here's my experiences... (very long) OBS3SSION Off-Topic 26 01-21-2005 11:41 PM
E46 Alarm FAQ !! swchang 3 Series / 4 Series 30 11-24-2004 12:11 AM
alarm activation w/o alarm swchang 3 Series / 4 Series 14 01-25-2004 10:29 PM
Ward's 2003 top engine list - 3.0 & 3.2L JPinTO General BMW 10 04-01-2003 08:12 PM
