Old 02-02-2006, 09:31 PM
jlipton jlipton is offline
Mein Auto: 08 335i e92 6MT Sport 230
Question Tire Pressure Monitor Initiation
I have an '06 325i, and it has run-flats, as they all do. I followed the instructions in the owner's manual to initiate the tire pressure monitor system, but there was no confirm or anything. So my question is: how do I know if it initiated properly?
Old 02-02-2006, 11:54 PM
tierfreund's Avatar
tierfreund tierfreund is offline
Mein Auto: E90 330i
Simple. You trust it.
No, NOT that kind of Tierfreund...
Old 02-03-2006, 08:53 AM
ic's Avatar
ic ic is offline
Mein Auto: 06 325i SP
It has a "check" mark beside INIT for confirmation.
Old 02-03-2006, 09:47 AM
ase2dais's Avatar
ase2dais ase2dais is offline
Arrive Alive w/ my e92 M3
Mein Auto: E90SG E92M3SG
thats is correct the second instance that you push the stalk, the check mark should appear, indicating that its been reinitialized. Any significant reading from these tires as they rotate will trigger an dashboard alarm.
I had a false alarm with these indicators mind you while running non-RFT,
when i inspected and check all pressures and all indicated ok!
just an fyi.
Old 02-03-2006, 11:07 AM
ic's Avatar
ic ic is offline
just and fyi.
fyi...I don't get false alarm with my winter non-RFT tires.
Old 02-03-2006, 12:32 PM
ase2dais's Avatar
I had a flute few miles after I put on the non-RFT, to think of it now, I may have not reinitialized it after switching tires,
and maybe the system were still thinking I had the other set of RFT on.
but after that now other problems with my non-RFTs.
Im not saying non-RFT will give you error/flute readings.
Similar Threads
checking tire pressure...a cautionary tale car_for_mom Tire Rack's Tires, Wheels, Brakes & Suspension 21 11-12-2005 06:24 AM
Correct Tire Pressure for X3 3.0i (2005)? Caesar X3 E83 (2004 - 2010) 4 06-11-2005 06:36 PM
Tire pressure difference between early and newer E46s blazingbeat E46 (1999 - 2006) 12 04-03-2005 08:36 PM
Correct tire pressure dinanti 3 Series & 4 Series 2 01-27-2003 03:51 PM
325Ci Coupe tire pressure ques. - DJ not right Scotes 3 Series & 4 Series 2 03-01-2002 02:14 PM
