E46 (1999 - 2006)
Old 02-02-2006, 04:19 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
today's mod.. alcantara e-brake handle
from the guys over at LeatherZ of course.
*grunts* Alcantara good!
I wonder if it weighs less than the leather? I could have just saved a gram! It's like 5hp per gram of weight savings, right?
Old 02-02-2006, 04:24 PM
AleksT AleksT is offline
Send a message via AIM to AleksT Send a message via Yahoo to AleksT
Mein Auto: 97 M3
Very nice looking mod. How long did it take to complete? Any install process pictures?
Old 02-02-2006, 04:36 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Oh, maybe an hour or so. The kit from LeatherZ comes with the entire lever, since the handle doesn't separate from it.
I lost the install instructions from LeatherZ, but it was a breeze to figure out.
The first step is to remove the center console area. The instructions for that can be found on Adam's Bluetooth Install page:
here
You'll need a deep 10mm socket to remove the two nuts on the end of long bolts which are actually connected to the ebrake. You have to remove a little clip that holds a the ebrake sensor wire on. From there, there are 3 13mm bolts that hold the lever itself on. Everything else is the reverse . There is just a zip tie holding your existing boot to the lever, you simply cut it and use a new zip tie to attach the boot to your new handle.
I used the opportunity to hand wash my ebrake boot in the sink with some woolite, as well as washing down the entire center console area. That added some time to the install.
Old 02-03-2006, 11:46 AM
Burrogs's Avatar
Burrogs Burrogs is offline
Mein Auto: '04 330i ZHP 6-sp AW
Your E-brake kinda looks like a fuzzy little woodland creature . You should put a stuffed animal head on the button or something to complete the transformation.
2004 330i ZHP 6-spd, Alpine White/Black Cube/Alcantara, Koni FSDs w/ Eibach Prokit, no CDV, M3 RTAB with Vorschlag limiters, ULO-OEM Clears, Lightwerkz TFX upgrade, Blackout Kidneys, OEM M3 Strut Brace, OEM Bluetooth retrofit, DIY Clutch Stop, Sirius, Dr. VANOS kit, iPod integration
Old 02-03-2006, 09:51 PM
MrMotorwerk's Avatar
MrMotorwerk MrMotorwerk is offline
automotive ballet
Mein Auto: 2002 330Ci mit Alpina
Looks nice.
Old 02-21-2006, 11:47 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Kris,
Looks great! Can I use thes pics on our site?
Old 02-21-2006, 11:50 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Originally Posted by AndyM
Kris,
Of course!
Old 02-22-2006, 10:36 AM
JWD JWD is offline
Mein Auto: 2002 745li
alcantara steering wheel
Do you know if Leather Z can put Alcantara on a steering wheel? I drove the Mercedes CLS55 AMG with an Alcantara steering sheel that was awesome. THanks
Similar Threads
e brake handle removal johndddd 1M & M2 2 04-14-2004 03:03 AM
e brake handle install johndddd 1M & M2 4 04-11-2004 01:24 PM
WTB: Emergency Brake Handle Stock Black Leather Cybertek Classifieds 1 02-02-2004 05:40 PM
Will this brake handle fit in a Zcoupe? mng E36/7 Z3 (1996-2002) 12 11-21-2003 09:31 AM
Emergency Brake Handle Replacement mbushnell Do-It-Yourself H.Q. 8 10-15-2003 03:25 PM
