E46 M3 (2001-2006)
Old 02-02-2006, 05:48 PM
jayf jayf is offline
Mein Auto: 2002 m3c
Rear Brakes DIY Question
My rear brake pads are getting thin after 85,000 miles on my '02 M3 Conv and the idiot light just came on telling me that. Does anyone out there know the exact minimum thickness of the rotor before it should be thrown out? Does anyone know how to reset the brake indicator light on the dash after I replace the pads (and possibly the rotors too)?
Old 02-02-2006, 06:29 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
AFAIK, BMW doesn't recommend turning rotors and the light will go out once you replace the sensor that attaches to the pads.
Old 02-03-2006, 07:49 PM
27rotax 27rotax is offline
Mein Auto: '01 M3, '88 M3, '95 525i
Bentley Publishing wrote a nice manual for e46 cars which includes the m3... expensive, but well worth it. Rotors are actually reasonably priced, so they are usually replaced rather than cut. And as with the previous reply, you need to replace the sensor that is attached to the right side pads, and the light will go out. If you replace pads before the light comes on, you can reuse the old sensors. It's not a tough procedure... good luck!
Old 02-03-2006, 08:09 PM
GregW in Oregon GregW in Oregon is offline
Mein Auto: '15 M4 Coupe; '12 ML350
Rotor thickness
I don't recall the exact number, but it should be stamped on the hat. If you don't have a rotor caliper, measure with a regular caliper with shims each side, then subtravt the thickness of the shims.
Greg Lake Oswego, Oregon
2015 M4 Coupe - Silverstone/Sakhir/CF
2012 M-B ML350 - Arctic/Black/Satin Ash
Old 02-05-2006, 05:16 AM
Mein Auto: 2002 m3c
Reasonably priced rotors? They are about $275 each. I do not consider that reasonable.
Old 02-05-2006, 07:59 AM
Rotor prices
You're getting ripped. You can get the factory Euro rotors for $209/ ea rear at Turner ($240/ea. front).
http://www.turnermotorsport.com/html...ParamCat=E46M3
Old 02-12-2006, 06:04 AM
Mein Auto: 2002 m3c
I did the rear brake job, no hassles. I bought the new sensor, but the sensor wire hides underneath the car. Am I supposed to remove body parts under the car just to get at it? How dumb is that? Can I splice the new wire for the old wire rather than tearing the under carriage of my car up?
When I did my fronts, the wire was easily accessible.
Old 02-12-2006, 08:57 AM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
Why replace the sensor? Just use the existing one.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 02-13-2006, 06:57 AM
Mein Auto: 2002 m3c
I put the existing one back, but the light on the dash stays on. Unless there is some reset procedure? Is there a dash light reset procedure?
Old 02-13-2006, 07:35 AM
elbert's Avatar
elbert elbert is offline
Sikkens Autocryl MM
Mein Auto: Ford Tempo GL
Also consider Powerslots for $142/ea. or Frozen Rotors for $130/ea. at Tirerack
Old 02-17-2006, 12:22 PM
acitydweller acitydweller is offline
Mein Auto: 2001 E46
Are either rotors as good as the oem?
Old 02-23-2006, 11:08 AM
elbert's Avatar
Sikkens Autocryl MM
I had Powerslots on a different car (street use only) and they seemed ok. However I'm a bit leery of using slotted rotors on the track, so I'm going to order the cryo treated rotors for this car in the next couple days. Seeing how much cheaper they are than the OE rotors, I'll be happy as long as they don't fail catastrophically.
Similar Threads
Rotora Brake System Performance on BMW M3 Racer Car ralphwarren Motorsports, Racing & Track 6 03-13-2009 06:00 PM
new rotors & pads, rear brakes squeak at low speeds f_richey E36 (1991 - 1999) 4 10-07-2005 10:24 AM
M3 rear offset question batmanm3 Do-It-Yourself H.Q. 7 05-25-2004 07:15 PM
Rear End Ratio change question.... FlyingDutchMan 1M & M2 10 09-29-2003 12:28 AM
rear shock mounts question bonrob General BMW Questions 0 08-01-2003 03:06 AM
